Power steering - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-22-2006, 09:37 AM   #1 (permalink)
virginia is for lovers...
applesauce's Avatar
View applesauce's Photo Gallery
Power steering
I have an unusual sound. Sounds like the alt. or the power steering pump. The alt just got rebuilt about a year ago though and tested out good, so im not sure. I have lots of miles on this motor so, how often do power steering pumps go bad? I just replaced all 3 belts and the noise got louder...
applesauce is offline   Reply With Quote
Old 12-22-2006, 10:13 AM   #2 (permalink)
Got Hardass?
Jeeves's Avatar
View Jeeves's Photo Gallery
Where is the noise coming from?
Old 12-22-2006, 02:57 PM   #3 (permalink)
7MGTE/22RE
shaeff's Avatar
View shaeff's Photo Gallery
start by checking the power steering fluid. if you're low, it'll make all kinds of pretty sounds.
-shaeff
My heater core replacement writeup with pics: http://www.toyotanation.com/forum/t209136.html
1994 Toyota 4x4, 31x10.50, 22re. <- to undergo high compression 7MGTE swap whenever i finish building it.
1986.5 Toyota Supra- 300+rwhp. (capable of over 400, but i haven't tuned it yet)
shaeff is offline   Reply With Quote
Old 12-26-2006, 01:57 PM   #4 (permalink)
applesauce's Avatar
power steering
My fluid is full and all the belts have been changed. The noise seems to be coming from the left side looking in from the front. Maybe the oil pump? Isn't that down under by the power steering pump on the left side?
Old 12-26-2006, 04:44 PM   #5 (permalink)
7MGTE/22RE
shaeff's Avatar
the oil pump is located in the oil pan, pretty much dead center. if it's an external noise, chances are that it's an accessory drive causing it. try taking off the powersteering belt. if the noise goes away, you've found the culprit.
are you using the correct fluid in the powersteering? it takes ATF, not actual powersteering fluid.
-shaeff
Old 12-26-2006, 06:09 PM   #6 (permalink)
Got Hardass?
Jeeves's Avatar
My guess is that the noise is coming from the power steering pump.
Old 12-26-2006, 09:47 PM   #7 (permalink)
one turbo is one too few
bgrieger's Avatar
Gameroom cash: $309150
View bgrieger's Photo Gallery
Your PS pluid may be full, but the screen in the bottom of the reservoir may be clogged, starving the pump hence the noise. Try removing it, and spray some brake cleaner in there, or pour in a dunk degreaser. shake it out well, and keep repeating until it appears fairly clean. Peer in with a flashlight to see how clean it is, then let dry, and flush it with a splash of ATF before you reinstall it. Bleed by turning it lock to lock while running and pouring in new fluid.
bgrieger is online now   Reply With Quote
Lexus IS Pricing (Canada) lexusis350 Toyota News 28 10-01-2007 11:30 AM
Power Steering problem.. MR2crazybyong MR2 Forum 13 01-22-2006 08:22 PM
power steering fluid change gen3 OMNI 3rd & 4th Generation (1992–1996 & 1997–2001) 3 01-12-2006 02:23 PM
power steering fluid change gen3 OMNI 3rd & 4th Generation (1992–1996 & 1997–2001) 0 01-11-2006 05:46 PM
Power steering replacement. 1987camry Camry & Solara Lounge 0 08-10-2002 04:08 PM
