1986.5 NA to Turbo Conversion - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-17-2007, 05:45 AM   #1 (permalink)
MA70 NA
Kaneda's Avatar
View Kaneda's Photo Gallery
Hey dudes, im new here and i am just lookin for a couple opinions. On an N/A MA70 is it an easyer route to just turbo the NA block with a fuel controller, FPR and a few other goodies or is it a better idea to switch over the whole turbo motor plus ecu and harness? how hard is the engine harness changeover? can anyone direct me to a site with a documented swap? Thanks!
Kaneda is offline   Reply With Quote
Old 01-17-2007, 03:23 PM   #2 (permalink)
View dgoodhue's Photo Gallery
Given the current prices of the MKIII's, I would just sell your car and buy a 87 up Turbo MKIII. I am all for a project, but their is no sense in reinventing the wheel when it was already done from the factory. Your going to spend a lot of time and probably similiar $ to to get the same result.
Dave
02 Highlander
dgoodhue is offline   Reply With Quote
Old 01-17-2007, 04:55 PM   #3 (permalink)
View jon_570's Photo Gallery
i agree
jon_570 is offline   Reply With Quote
Old 01-17-2007, 05:14 PM   #4 (permalink)
Got Hardass?
Jeeves's Avatar
View Jeeves's Photo Gallery
Either a 7M-GTE Swap, or buy a turbo car. NA's aren't that grand for turbo-ing, and either way you'll still need/want to do a metal head gasket.
Old 01-17-2007, 07:29 PM   #5 (permalink)
MA70 NA
Kaneda's Avatar
Hmm well it looks like i have some thinking to do. BTW does anyone know what the stock ECU can handle for boost?
thanks!
Old 01-17-2007, 07:45 PM   #6 (permalink)
the fuel cutoff for a 7mgte is 12psi
Old 01-17-2007, 11:04 PM   #7 (permalink)
MA70 NA
Kaneda's Avatar
Any idea if its the same on the 7mge?
Old 01-18-2007, 08:41 AM   #8 (permalink)
Considering its a different ECU, it doesn't have any provisions for boost cut, but that also means it doesn't have correct fueling for boost either. The injectors are small 295cc (vs Turbo 440cc) and I would guess the 7m-ge AFM probably maxes out pretty early as well. You sound like rookie when it comes to turbo's, and properly fueling a non turbo motor isn't a rookie project...
Dave
02 Highlander
Old 01-19-2007, 08:16 AM   #9 (permalink)
MA70 NA
Kaneda's Avatar
Just a newb to Toyota, never owned one before but i know my way around a turbocharged motor.
Old 01-19-2007, 11:13 AM   #10 (permalink)
7MGTE/22RE
shaeff's Avatar
View shaeff's Photo Gallery
if you poke around enough, you'll see there are very simple ways to get past fuel cut. (lex afm, is the easiest route, coupled with 550cc injectors. or, the maftpro is much better, and allows you to convert to speed/density, which is the route i took)
-shaeff
My heater core replacement writeup with pics: http://www.toyotanation.com/forum/t209136.html
1994 Toyota 4x4, 31x10.50, 22re. <- to undergo high compression 7MGTE swap whenever i finish building it.
1986.5 Toyota Supra- 300+rwhp. (capable of over 400, but i haven't tuned it yet)
shaeff is offline   Reply With Quote
Old 01-20-2007, 06:09 PM   #11 (permalink)
I Bleed TRD
willtotheumm's Avatar
View willtotheumm's Photo Gallery
Just get the 7mgte...like they said it'll be easier.
Which gets me thinking...on mine (7mgte), it has the oil squirters inside of it. Does the 7mge have those too? Or would those need tapping into the oil line?
1988 Supra Turbo- Stock 7M-GTE, 5-speed manual, HKS Turbo timer, ARP headstuds, planning 2jz-gte swap
1988 MR2- Stock 4a-ge, 5-speed manual, planning 20v swap
My Cardomain / My Myspace
willtotheumm is offline   Reply With Quote
Old 01-20-2007, 07:46 PM   #12 (permalink)
one turbo is one too few
bgrieger's Avatar
Gameroom cash: $309150
View bgrieger's Photo Gallery
the GE does not have squirters. I've never seen anyone who did the NA/T swap bother with them. Some theorize the higher oil pressures from not having them are more beneficial than the extra cooling is...I'm not sure which would be the better starting point either, but figure that Toyota doesn't spend on extra parts it doesn't think are needed/of benefit.
bgrieger is online now   Reply With Quote
Old 01-21-2007, 04:22 PM   #13 (permalink)
MA70 NA
Kaneda's Avatar
Thanks for the help guys! has anyone considered trying to run Emanage on an NA-T project?
Old 01-22-2007, 02:08 AM   #14 (permalink)
Got Hardass?
Jeeves's Avatar
E-Manage Blue's are all over in the 7M's. Ultimates don't seem to work so great for one reason or another.
Old 01-22-2007, 08:11 AM   #15 (permalink)
MA70 NA
Kaneda's Avatar
Yea, i have seen a few run on the Emanage, but i havent come across any pinouts for the NA ECU, just turbo, and i havent seen anyone run the system itself on an NA-T
2VZFE NA Buildup (or Turbo??) JetspeedCamry Camry & Solara Lounge 26 04-03-2009 04:22 AM
the 5sFE Turbo Upgrade Info Zrain Celica Forum 25 08-14-2007 12:31 AM
My Official Turbo Post!!! 97camryman Camry & Solara Lounge 25 07-20-2006 04:48 PM
suspension differences between NA and Turbo SW21 MR2 Forum 4 04-12-2006 10:20 AM
1990 MR2 2.0 Turbo Conversion? Gouki MR2 Forum 11 07-27-2005 09:50 AM
