turbo - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-12-2003, 05:03 PM   #1 (permalink)
View 7M-GTE's Photo Gallery
turbo
can u do this 2 a 2nd gen supra turbo (7m-GTE) i was wondering if u could get 2 turbos and each one to run off 3 cylinders so....one turbo per 3 cylnder...ahh do u not how easly this cood be dun and where i cood get an exhaust manifold for that
7M-GTE is offline   Reply With Quote
Old 06-17-2003, 10:48 AM   #2 (permalink)
View cdnsupra's Photo Gallery
i have never heard of this being done, but anything is possible with knowledge and money.
to get the most power for the least money, you are better off not reinventing the wheel, unless you want something very unique.
the tested and tried routes are turboing the 5m-ge with a 7m manifold and turbo of your choiuce, or install the whole 7m. others have recently put 1jz's, 2jz's, and other variotions as well.
ben
Ben
CdnSupra from Hamilton
91T, stage 3+[87T has been retired]
cdnsupra is offline   Reply With Quote
Old 06-22-2003, 05:31 AM   #3 (permalink)
View ecko344's Photo Gallery
www.turboboss.com makes a twin turbo manifold for the 7M-GTE.
MKIII Supra Turbo
ecko344 is offline   Reply With Quote
Old 06-26-2003, 10:02 PM   #4 (permalink)
one turbo is one too few
bgrieger's Avatar
Gameroom cash: $309150
View bgrieger's Photo Gallery
Too bad turbo boss comes with such a bad name, and that manifold leaves quite a bit to be desired. To do it right is all custom work. The basics of the project would require the use of 2 larger compressor T3 or very small compressor T4 turbos, and the exhaust housing side is still only a guess on my part (haven't ventured too far into that side's research yet). Then, 2 custom, equal length 3 cylinder manifolds, 2 downpipes, 2 wastegates, full fuel upgrades and finally a standalone EMS to get it running properly (lexus AFM and an SAFC may not be enough to control the fueling properly as the boost curve will be nothing like the CT-26).
I've been planning a twin project for a couple of years, though time and money are the 2 limiting factors...so many upgrades and restoration projects...so little time and money left! In all, budget somewhere near $7-9k for this little gem, and even that may be a little on the cheap side.
Bob
bgrieger is online now   Reply With Quote
Old 06-27-2003, 07:01 AM   #5 (permalink)
sure makes the sp63 upgrade at 5k us a lot nicer.
if you are an inventor, go ahead and re-invent the wheel. if you are a following, go with what works.
Ben
