need help " check engine" - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-23-2003, 04:10 PM   #1 (permalink)
kristoffer's Avatar
View kristoffer's Photo Gallery
Whats up guys?
I need help again. I was driving a friend home and I noticed that the engine check sensor start popping out on my MKIII non turbo. So I wonder what could it be. Any kind of help would be appreciated thanks.
Thanks in advance,
Kristoffer
kristoffer is offline   Reply With Quote
Old 06-24-2003, 08:16 AM   #2 (permalink)
View cdnsupra's Photo Gallery
you need to check the codes. behind the battery, you will see a DIAG diagnostic port. it is black plastic, about 1 inch by 1 inch. pop it open.
in side, you will see a bunch of terminals. put a short wire, or paperclip between t and e1.
then get in the supra, and turn ignition to on, but do not start.
the check engine light will flash. count the groups of flashes
3...2.......5...6.......2....1...............3..2. ......5..6.........2...1 repeating...
this tells you the codes 32,56,and 21 are stored in your computer. goto supras.com and check what the codes mean, and what you need to fix.
Ben
CdnSupra from Hamilton
91T, stage 3+[87T has been retired]
cdnsupra is offline   Reply With Quote
Old 07-13-2003, 10:44 PM   #3 (permalink)
View lattimerwillard's Photo Gallery
need help check engine
I have a 99 Corolla. My check engine light stays on most of the time. It started about two weeks after I had it inspected on the same day I filled the tank with gas. I bought a new gas cap. Days later I disconnected the battery for 15 minutes, hoping the computer would reset itself. I took it to a mechanic, who checked everything but could not find a reason for the light to come on. He asked me to bring the car back so that he can check if the code changed after we started driving it and the light came back on. Any thoughts?
lattimerwillard is offline   Reply With Quote
Old 07-14-2003, 02:07 PM   #4 (permalink)
kristoffer's Avatar
Diagnosis read 52
Ok guys I did a diagnosis check on my check engine problem. The count that I got is 52 which is the following; knock censor, short circuit on my knock censor and ECU.
Question?
Where's my knock censor located?
What are the basic things that I have to do?
I dont really bring my car to the shop I like to know my car more.
any single help would be apreciatted.
Thanks in advance,
Kristoffer
Old 07-14-2003, 08:56 PM   #5 (permalink)
the knock sensors are tough. i have never fixed them in either of my supras, but my red one is throwing that code now as well. there are 2 knock sensors, on the drive side of the engine, near the furl rail. they are a pain in the arse to get to.
most of the time, the sensor is fine, and it is the cable that has a short it in due to the age and searing heat in the engine. people have replaced them with heavy duty co-axial cable wire, and move on to other problems.
if you go check out www.supras.com, follow the link to the TSRM(Toyota Service and Repair Manual), you can print off exact instructions to fix and replace the knock sensors or cable.
cheeeers. ben
p.s. after you get your done, how bout coming over to help me with mine.
Ben
Old 07-15-2003, 07:02 PM   #6 (permalink)
kristoffer's Avatar
How about we do it at the same time just let me know what day are you free. Just give me a shout I'll be happy to help you out.
Kristoffer
Old 07-15-2003, 08:05 PM   #7 (permalink)
if i fix mine in the 87, it will be after i pull the motor and part it out.
Ben
Old 07-16-2003, 10:55 AM   #8 (permalink)
kristoffer's Avatar
Ok i guess i will fixed mine first somewhere around this week and let me know if you need any help on yours im always free to help.
Kristoffer
Old 07-16-2003, 02:34 PM   #9 (permalink)
Let me know when you are going to do it. i'll see if i can get away and give you a hand.
i am busy tonight, and on the weekend.
Ben
Old 07-16-2003, 07:41 PM   #10 (permalink)
kristoffer's Avatar
Im not sure probably next week. Im free Tuesday, Thursday and Friday every week coz thats my dayoff everyweek. So just let me know which day Im not in a hurry anyways, take your time.
THanks,
Kristoffer
