Fuel Cut-out - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-17-2007, 01:56 PM   #1 (permalink)
Shatonapples's Avatar
View Shatonapples's Photo Gallery
Fuel Cut-out
My supra is completely unmodified at this point, it has a brand new head gasket, and I haven't really seen any problems yet since then (except the fan shroud that fell into my fan, so I replaced the fan with an electric one.) Anyway, at the track, immediately after the head gasket was replaced, I was dragging it, just to see what kind of times I could get. Best I could manage was around 15.2, reason being, at the top of third I was getting fuel cut-out for some reason. After hard acceleration up to about 80 the fuel cuts out. Anyone have any idea what could be causing that?
If it matters I'll list what I've replaced:
Head Gasket
Timing Belt
Valve Cover Gasket
Water Pump
It still performs, but it would be nice if I could eliminate the fuel cut-out. Let me know if you have any ideas!
1987 Supra running 3" Turbo-back exhaust on a 7M-GTE @ 11.7PSI.
Greddy Turbo timer, wideband O2, AEM Air-Fuel Gauge, and Greddy Boost Controller installed.
Project '87 MR2 almost running.
Shatonapples is offline   Reply With Quote
Old 03-17-2007, 05:11 PM   #2 (permalink)
one turbo is one too few
bgrieger's Avatar
Gameroom cash: $309150
View bgrieger's Photo Gallery
If you're hitting fuel cut, you have a boost leak somewhere, or your wastegate has a problem. Given the times you list, I'm going with leak. Your turbo is working enough air to hit the volume required for fuel cut, but it isn't developing the pressure to open the wastegate. Find the leak, and cut goes away!
Your fuel mileage will also be the pits while its like this...the ecu "thinks" all that air is getting in the cylinders, and will push the fuel richer than it actually needs to be.
bgrieger is online now   Reply With Quote
Old 03-18-2007, 07:15 PM   #3 (permalink)
Thank you for the response, I will have to explore your hypothesis. I hope it works and I"ll be back to let you know...when I get around to checking into it =).
Old 03-18-2007, 11:48 PM   #4 (permalink)
Got Hardass?
Jeeves's Avatar
View Jeeves's Photo Gallery
Bob said it best. Boost Leak.
Old 03-21-2007, 01:11 PM   #5 (permalink)
Pacquiao for president
supra saiyan's Avatar
View supra saiyan's Photo Gallery
It might also be your sparkplugs being blown out.
supra saiyan is offline   Reply With Quote
Old 03-21-2007, 06:19 PM   #6 (permalink)
Got Hardass?
Jeeves's Avatar
I've never heard of fuel cut due to losing spark. They feel very different. One is like just losing power, the other feels like "Power, power, power, running into a brick wall".
Old 03-21-2007, 06:26 PM   #7 (permalink)
I didn't mean to imply that it was fuel cut due to the plugs being blown out; I meant that it might not be fuel cut at all, and it might be spark being blown out instead.
Old 03-21-2007, 09:10 PM   #8 (permalink)
bgrieger's Avatar
spark blowout on a stock car? That's a new one for me...
Old 03-22-2007, 04:28 PM   #9 (permalink)
Got Hardass?
Jeeves's Avatar
If it's running N/A plugs or the like it could happen, N/A's have a gigantic gap in comparison.
Either way, Saiyan, what I was saying is they are very different from each other. One's a brick wall, the other is a loss of power.
For Sale Brand New Camry Hybird for just $19000 cars01 Camry Hybrid 1 04-07-2007 06:00 PM
Carburetor fuel cut solonoids - mixed up? larrymoencurly Archived Corolla threads 1 02-21-2006 07:53 PM
getting rid of fuel cut bad7mgte Supra Forum 10 11-22-2004 10:16 PM
Fuel Cut 91 turbo MR2 Forum 5 08-09-2004 08:24 PM
Fuel cut question.... Piddy MR2 Forum 2 08-05-2004 08:21 AM
