difference between usdm and jdm 2JZGTE - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-17-2007, 08:12 AM   #1 (permalink)
View jdizzle318's Photo Gallery
i was wondering what the main differences between the usdm and jdm versions of the 2JZGTE are since one has 40 more hp any anwsers would be greatly appreciated
-jd
jdizzle318 is offline   Reply With Quote
Old 04-17-2007, 08:41 AM   #2 (permalink)
NFS: Most Wanted
toyosupra_87's Avatar
View toyosupra_87's Photo Gallery
http://i-supra.com/eve/forums/a/tpc/...1/m/3926067711
Japanese Market Supra Twin Turbo -vs.- U.S. spec Supra Twin Turbo
Engine Specs
Model: (Japan Spec.) / U.S. Spec
Horsepower: (280hp@5600) / 320 hp
Torque: (318ft/lb@3600) / 315 ft/lb
Injectors: (430 cc) / 540 cc
Injector Impedance: (High Impedance) / Low Impedance
Inlet Cam Duration: (224 deg) / 233 deg
Inlet Cam Lift: (7.8mm) / 8.25mm
Airflow Measurement: (MAP sensor) / Mass-Airflow sensor
Turbos: (CT12B Japanese) / CT12B U.S.
Turbine Size: (60mm/48mm) / 52mm/44mm
Compressor Size: (62mm/39mm) / 58mm/39mm
Turbine material: (Ceramic) / Steel
Scroll area (mm^2): (600) / 740
A/R ratio: (0.42) / 0.53
Japanese Spec ¼ mile Performance:
14.0 @ 101mph
U.S. Spec ¼ mile Performance:
13.6 @ 106mph
Differences in features (U.S., Japan, Europe):
-Retractable Front Spoiler (Japan, Europe)
-Glass Lense Headlamps (Europe)
-Reverse lamp in different location on tail lamps (Europe)
-Analog Clock (Japanese later models?)
-Headlamp washers (Europe)
-No side lamps on bumpers (Europe)
-Side Lamp on fender (Europe)
-Hood Scoop for cooling turbos (Europe)
-Rear External Differential Fluid Cooler with fluid pump (Europe)
-Twin Automatic Transmission Coolers (Europe)
-6N0 Gray Exterior Color (Japan)
-756 Yellow Exterior Color (Japan)
-5 Gauge Dash
-Right Side Drive (Japan, Some Europe)
Mike T
94 Supra TT 6spd
"Silly ricer, synchros are for kids"
93 Jeep Grand Cherokee Laredo/87 Toyota Celica GTS/87 Toyota Supra Turbo - sold it
1995 Toyota Avalon XLS - Awsome car, Still ALIVE
1994 Toyota Supra TT - under contruction/rebuild
1997 Dodge Caravan-family van/winter beater
toyosupra_87 is offline   Reply With Quote
Old 04-17-2007, 09:04 AM   #3 (permalink)
thanks man thats helps out alot i want to put a 2jzgte in my sc and usdm ones are a bitch to find so ill prolly have to go with the jdm motor and i plan to replace the turbo system etc. so it shouldnt be that big of a deal anyway
-jd
well.......we could always try with a bigger ballpene
Old 04-18-2007, 05:16 PM   #4 (permalink)
I Bleed TRD
willtotheumm's Avatar
View willtotheumm's Photo Gallery
dang we have a lot more ponies but they beat us by a few ft/lbs. Arent the JDM ones limited to the Japan regulated limits? Isnt it 280?
1988 Supra Turbo- Stock 7M-GTE, 5-speed manual, HKS Turbo timer, ARP headstuds, planning 2jz-gte swap
1988 MR2- Stock 4a-ge, 5-speed manual, planning 20v swap
My Cardomain / My Myspace
willtotheumm is offline   Reply With Quote
Old 04-18-2007, 08:50 PM   #5 (permalink)
View Nick 95 6sp's Photo Gallery
I thought that the 280 hp for the JDM Supra was either a "gentleman's aggreement" or maybe even a law in Japan, that no car would have over 280 hp, so guess what, the Supra has 280 hp, the Skyline has 280 hp. In reality, the power was very close to USDM Supras though with some "significant" mechanical/elect differences as nicely outlined above.
Once you start moding and increasing boost well above stock, the JDM ceramic turbos are more delicate and with smaller injectors, if you can't flow fuel you can't flow air so less max power from stock fuel system.
'07 RAV4 Classic Silver LTD, V6
'95 Supra 6sp APU
'04 TSX
Nick 95 6sp is offline   Reply With Quote
Old 04-19-2007, 09:37 AM   #6 (permalink)
Got Hardass?
Jeeves's Avatar
View Jeeves's Photo Gallery
The 280ps was a gentlemans agreement, but beyond that it was nothing. Stock numbers on GTR's and Supra's often surpassed the 280 mark, it was only listed as such so that marketing didn't turn into a sheer hp contest.
From Wiki:
A now-defunct agreement between the major Japanese auto manufacturers to limit the maximum advertised engine power of their cars to 280 PS (206 kW or 276 hp).
diffence between USDM and JDM 3sgte motors pdxvento MR2 Forum 16 05-20-2012 02:31 PM
Gen2 3sfe (USDM) vs. Gen3 3sfe (JDM) - What's the Difference? airswoosh1 1st & 2nd Generation (1983–1986 & 1987-1991) 15 12-24-2005 12:10 PM
USDM sold as JDM warlock Camry & Solara Lounge 21 10-03-2005 01:18 AM
jdm usdm ecu xploder98 MR2 Forum 5 09-10-2004 05:20 PM
how to tell...4AGZE JDM, or USDM, help! thanks! hoggie MR2 Forum 2 08-01-2004 08:56 PM
