CV Axle Assembly - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-12-2003, 01:39 PM   #1 (permalink)
View R. Walter's Photo Gallery
CV Axle Assembly
Subject: 85 Supra, manual
Problem: Annoying ringing sound coming from right rear of car periodically when underload or coasting.
I've removed the right rear CV Axle assembly and have ordered a new one. I also wanted to check and R&R the wheel bearings in the right rear wheel cylinder while I was in there.
Question: How do I remove the rotor/hub assembly?
I've removed the 27mm nut from inside the hub that was exposed when the CV axle assembly was removed. Now, I believe that the hub/brake rotor should pop off the underlying hub which will then expose the wheel bearings. Pounding, prying, pissing and cursing has not yet been successful. Is there a special jaw puller to remove the hub/rotor assembly?
Thanks to any and all for help.
R. Walter is offline   Reply With Quote
