88 Supra alternator fuse 100 A - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-23-2007, 03:45 PM   #1 (permalink)
View Rancherj's Photo Gallery
Canada 88 Supra alternator fuse 100 A
88 Supra 7mgte
yep mine is blown and I need to know the best way to get it out!
Remove fuse block? (unbolt ) go from below
Can I get at it from on top? retaining clips?
Rancherj is offline   Reply With Quote
Old 04-25-2007, 06:44 AM   #2 (permalink)
Thumbs up Got it
Unfastened Fuse block, unclipped tray beneath said block, released section with 100A fusible link held by retaining clip (in slot directly beside 100A fuse), module slipped out bottom of fuse block, two philips screws holding fuse, done
Old 04-25-2007, 08:00 AM   #3 (permalink)
one turbo is one too few
bgrieger's Avatar
Gameroom cash: $309150
View bgrieger's Photo Gallery
you missed a step...purchase 2 fuses. After installing the first, find out what blew it and fix the problem. You shouldn't have anything that can draw 100 amps short of a large stereo, and that should be wired off the battery directly and fused seperately. None of the stock wiring was meant to handle 100 amps outside of the starter!
(the second fuse is in case you have to experiment to find the source of the problem).
bgrieger is online now   Reply With Quote
Old 04-25-2007, 09:09 AM   #4 (permalink)
thanks for the input. Fried it when I dropped a wrench across the batt. terminals while installing after winter. should have included that info on original post.
I wish I had a stereo big enough to worry about power supply issues
Old 04-25-2007, 02:37 PM   #5 (permalink)
bgrieger's Avatar
That would torch the fuse in short order...Problem found!
Supra to Cressida Swap Spektyr Cressida Forum 21 01-31-2012 03:21 PM
pcv location 88 supra redevil Supra Forum 4 02-01-2005 02:16 AM
hey every1, just recieved 88 supra Help 88supraTony Supra Forum 21 12-15-2004 02:25 PM
88 Supra For Sale 88SupraMKIII Supra Forum 0 08-13-2004 04:49 PM
