the stock connections are still there, not hacked off.
I tested the power ones with the pointy end of the
circut tester down inside the connector, still no juice.
I did a search on the forum here, but still a bit
confused...on an 87 is the brown wire ground or
power?
My Haynes manual does not show the wiring
schematics for that particular year, the closest is
the 86.5 model, which seems to show brown as
power.
on the net I found a chart which says stock wires:
+12V ignition = gray
+12V battery = blue/w yellow stripe
Ground = black ( I think my ground is brown )
while looking under the steering column I found
a plain brown wire, connected to a blue wire
going to the alarm brain. heres a pic ...
Im trying to find where the wires go to the
drivers side kick panel fuse box, so I can
test for power there, but having no luck yet.
