brake issue - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-27-2007, 06:14 PM   #1 (permalink)
View Clorox's Photo Gallery
brake issue
My front driver side tire locked up the other day, smoking out of the wheel well, its hydraulicly frozen when i open the bleeder fluid came out. After the fluid came out... i tried to bleed it and fluid does not bleed thru it. Now my pedal goes half way (like it needs to be bled) and then i get some braking. i was wondering were i should start i was thinkin either the master cylinder or i have kinks in the line.. i was thinkin i should see which brakes bleed first. Any ideas on how to make the diagnosis faster..
Clorox is offline   Reply With Quote
Old 05-27-2007, 07:21 PM   #2 (permalink)
Mine is better than yours
iTrader Score: 6 reviews
View Marc M's Photo Gallery
I say pull the caliper and see if the piston can be pushed back in, if it's being stubborn, you probably need a new caliper.
The master cylinder wouldn't cause this issue.
The problem is at the wheel somewhere....
Marc M
'06 Tacoma Dbl-cab, 4X4, V6, 6-spd, SR5 / TRD Off Road
'05 Corolla XRS 6-Spd
'00 Echo 5-Spd
'90 4Runner SR5 5-Spd - '86 Shortbed 4X4 5-Spd,SAS'd ASAP - '82 Supra 5-Spd
Take your automatic and "Stick" it........
Marc M is offline   Reply With Quote
Old 05-28-2007, 12:46 AM   #3 (permalink)
BANNED
View w203's Photo Gallery
Find out of your calipers are seized. Jack up the front, leave the car on neutral and try to spin the front wheels. Report back with result.
w203 is offline   Reply With Quote
Old 05-30-2007, 11:46 PM   #4 (permalink)
caliper moves fine.... if i go 2 bleed the brakes i get no fluid at the front at all..... so im leading towards the proprotion valve.. i can get fluid to bleed at both rears... not even a drop at the two front... i cant think of much else that can block both calipers..
IIM - Ksport Procomp Big Brake Kits - 8 PISTON!! ImageInMotion Supporting Vendor Sales 8 07-08-2008 12:21 AM
Brake Questions Aaagogo Celica Forum 7 03-28-2005 10:22 AM
gen2 brake light stays on... help... please.. busted_ride 1st & 2nd Generation (1983–1986 & 1987-1991) 2 09-24-2004 04:56 AM
Soft brake pedal when car is on--booseter issue? Lumberg Camry & Solara Lounge 6 09-16-2004 04:55 PM
