Starting Problems w 86 Supra
Ok, here is the situation, I have a 1986 non-turbo supra. Whenever I go to start the car, there is a chance that it will not turnover. Its like this, sometimes it will start up normally, and then there are times when it will not turnover the first time i turn the key. if that happens then the car will not turn over for at least a day. it will rotate for however long u turn the key, but it will not turnover. I took it to a repair shop, and they replaced the cold start injector and the coolant temp sensor. They also said that there was a draw of electricity somewhere that could be discharging the battery but i don't think this problem deals with the battery. Could someone point me in the right direction on what could be wrong? Thanks in advance.
