Air Flow Meter and ECU ? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-04-2007, 01:30 PM   #1 (permalink)
7M user
86.5rusty's Avatar
View 86.5rusty's Photo Gallery
Hey guys. I have an 86.5 N/A supra which im doing the 7mgte swap on. I have purchased the 7mgte with harness and r154 turbo trans. The problem is i dont think its coming with the ecu for it nor the air flow meter. I found an ecu for turbo motor with M/T but with yellow connectors and im not sure if it will work cause i believe the motor is from 88-89 supra. Can anybody relate to my situation. Also does anybody know the part numbers or which lexus vehicles i can get the AFM from.
86.5rusty is offline   Reply With Quote
Old 06-04-2007, 01:37 PM   #2 (permalink)
7M user
86.5rusty's Avatar
I read previous threads about AFM from lexus but need bigger injectors to avoid running the motor lean. If i do have the wrong ecu does any body know where i can get the right one.
Old 06-04-2007, 04:18 PM   #3 (permalink)
Got Hardass?
Jeeves's Avatar
View Jeeves's Photo Gallery
If the plugs fit, you're fine. Old ECU's have the wrong plugs for New Wiring harnesses. 88-89 was the change year for the car, so that doesn't mean much.
Get the Harness, look at the plugs, and go from there.
Old 06-05-2007, 10:46 AM   #4 (permalink)
7M user
86.5rusty's Avatar
alright thanks. now i have to wait and see if the plugs fit in the ecu when the motor comes in this week.should be in no later then friday. All i have to look for know is an Air Flow Meter and drop it all in the car.
Wow, I need help! please! Setheroo 89-95 Toyota Pickup/Hilux 7 06-05-2007 06:44 AM
Air Flow Meter mystery evtiska 89-95 Toyota Pickup/Hilux 19 04-09-2007 06:43 PM
Air Flow Meter Right Or Wrong One? charrliy525 Pre-88 Toyota Pickup/Hilux 1 07-12-2006 05:23 PM
Air Flow Meter Right Or Wrong One? charrliy525 Pre-88 Toyota Pickup/Hilux 0 07-09-2006 10:04 PM
