Lean Air-Fuel mixture - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-01-2007, 07:09 PM   #1 (permalink)
Shatonapples's Avatar
View Shatonapples's Photo Gallery
I finally got around to installing my wideband O2 and the gauge, and even at as low as I can go with my boost controller (8psi), I'm running lean pretty much all the time. Even at idle I'm running a little lean. Granted, I am a bit unfamiliar with air-fuel ratios, but I have a general understanding.
What is an approximate dangerous air-fuel ratio? Anything over 14.7? I assume it has to be fairly high, like 15 or 16 to really worry about.
What are my options of increasing fuel to make up for my lean mixture? Are bigger injectors my only option?
As always, I truly appreciate the help you guys offer here, it's always been a pleasure dealing with you all,
Hank
1987 Supra running 3" Turbo-back exhaust on a 7M-GTE @ 11.7PSI.
Greddy Turbo timer, wideband O2, AEM Air-Fuel Gauge, and Greddy Boost Controller installed.
Project '87 MR2 almost running.
Shatonapples is offline   Reply With Quote
Old 07-02-2007, 12:41 AM   #2 (permalink)
Actually, I was wrong. I'm running under 15.5 all the time, and at boost (10ish) it stays below 11, so I think I'm set. I'd still like to verify around when detonation happens though.
Thanks again,
Hank
Old 07-02-2007, 01:20 AM   #3 (permalink)
Got Hardass?
Jeeves's Avatar
View Jeeves's Photo Gallery
11.7:1 is what I TUNE for while in boost. Stock, the Mk3's run rich as pigs in boost. When you're in closed loop mode (below 68% throttle) it'll be all over the board but you can't tune or adjust the closed loop, so don't worry about it.
Old 07-02-2007, 06:39 AM   #4 (permalink)
Oh, sweet. Thanks man. I really appreciate it.
Trouble Codes abew330 3rd & 4th Generation (1992–1996 & 1997–2001) 9 02-09-2007 01:04 PM
Are you really concerned about MPG? Read this before posting! boone 2nd Generation (2005+) 45 06-04-2006 03:22 PM
List of Toyota CEL Codes Marc M 2nd Generation (2005+) 2 03-30-2006 12:49 PM
help newbie save '85 with fuel system problem leiniesred MR2 Forum 0 02-28-2005 09:49 PM
Ractive Ram Air system. Camry_rider Hardcore Tech and Competition 51 07-23-2004 11:03 AM
