need help with clutch - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-03-2007, 10:21 PM   #1 (permalink)
View kshawj's Photo Gallery
i recently drop a jdm motor into my 89 supra and got it started, but it wont shift at all. if i force it it would, but besides that nothing. i bleed the system and everything and it was okay. i reach my hand into the trans window and pulled out a ring. i dont know where the ring is supposed to go. i drop the tranny and found a ring in front where the fork would sit. i thinking the fork would probably sit in between rings?? if any body gots any info or any pics of how it would look like let me know. or where i can get the rings to replace it?? thanks
kshawj is offline   Reply With Quote
Old 07-04-2007, 12:42 AM   #2 (permalink)
View tgidavid's Photo Gallery
That's the throwout bearing. You should replace that whenever you install a new clutch.
tgidavid is offline   Reply With Quote
Old 07-05-2007, 11:20 AM   #3 (permalink)
Got Hardass?
Jeeves's Avatar
View Jeeves's Photo Gallery
Well, it could be several things. There are several lock rings that should go in the clutch as well. Is the shift collar (I don't know teh proper term) installed correctly? It's the neck that sticks out of the clutch itself, that you put the input shaft of the transmission through.
UPDATE: Clutch problem canadianae92 Archived Corolla threads 2 10-29-2005 05:13 PM
Clutch Questions nofear4189 89-95 Toyota Pickup/Hilux 0 10-02-2005 08:15 PM
My clutch has started slipping and I dont know why REAPER STRAIN Camry & Solara Lounge 55 09-19-2005 07:47 AM
new clutch = broken wallet eyz closd MR2 Forum 4 03-12-2005 04:16 PM
