Stock 87 Tune Up & Mods - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-11-2007, 12:21 PM   #1 (permalink)
View landtoy80's Photo Gallery
I am going to go over my stock 87 nonturbo Supra I just got, to see what it needs.
I use OEM Toyota parts on my Land Cruiser as Toyota parts are far better than after market parts for the LC.
Is this true for the Supra?
Things I will be checking and what parts should I use, OEM or after market:
airfilter, oiled KN type or oem?
plugs wire cap
belts
I am not into cold air kits or loud exhaust but is there any mods other than them it increase power or efficiency?
I installed a catch can on my Land Cruiser with high mi to keep oil out of the intake. Does the 7MGE motor suck oil throgh the crank case venting system?
Is there a link or site with more info like what I have been posting?
I plan on changing all the fluids belts any bad rubber parts.
What else should I check?
94 Land Cruiser 374,000 mi
96 Camry 1MZ-FE 230,000 mi
landtoy80 is offline   Reply With Quote
Old 07-11-2007, 01:08 PM   #2 (permalink)
one turbo is one too few
bgrieger's Avatar
Gameroom cash: $309050
View bgrieger's Photo Gallery
filter: you choose. I use K&N myself, others complain the oils end up on the karman vortech sensor and they suffer AFM failures. Your NA does not have that problem. You might consider a K&N drop in filter and use hte facotry air box.
Plug wires: I use oem for perfect fit against the plug valley gasket.
Plugs: I also use OEM plats. I've used NGK as well successfully for plugs. Stay clear of Bosch.
Cap: no idea...never owned an NA before
cold air kits: DIY for the NA. I'm not aware of anything other than strapping a K&N cone filter to the sensor.
catch cans help. Turbo owners know this more than na owners do.
Old 07-11-2007, 06:01 PM   #3 (permalink)
7MGTE/22RE
shaeff's Avatar
View shaeff's Photo Gallery
i use mostly OEM stuff for maintenance. for air filters, i highly suggest the Apex-i unit. check out this link:
http://mkiv.com/techarticles/filters_test/2/
but, if you don't over-oil the k&n you'll be fine. i have msd plug wires now, but i don't like them that much. (and i don't even use the plug valley gasket) they just don't feel like they fit well.
for spark plugs, i swear by autolite 3923 coppers. they're excellent. many high horsepower guys use them. true, Bosch plugs suck!
i run a greddy oil catch can. if/when you do this, MAKE SURE to have a vacuum source connected to the top of the can!
-shaeff
My heater core replacement writeup with pics: http://www.toyotanation.com/forum/t209136.html
1994 Toyota 4x4, 31x10.50, 22re. <- to undergo high compression 7MGTE swap whenever i finish building it.
1986.5 Toyota Supra- 300+rwhp. (capable of over 400, but i haven't tuned it yet)
shaeff is offline   Reply With Quote
Old 07-16-2007, 08:58 PM   #4 (permalink)
Is there anything else I need to do for a 90,000 mi tune up other than what is in the manual?
I am doing plugs wire cap rotor, tranny rad and diff fluid change, fuel and air filter, t-belt and other belts.
Timing, do I set to factory setting or do some advance do to elevation?
Old 07-16-2007, 09:14 PM   #5 (permalink)
bgrieger's Avatar
set to factory. The TCCS has a high altitude pressure sensor for automatic computer compensation.
For everyone that does mods or is thinking of doing mods? toku58 2nd Generation (2005+) 34 02-01-2011 09:02 AM
Any stock intake mods? t0eknee 5th & 6th Generation (2002-2006 & 2007-2011) 17 09-07-2010 06:07 PM
FS: All my mods for 02 Solara going back to stock krawzyazn Car Parts for Sale 2 10-05-2006 12:05 AM
Stock MR2 turbo comparisons Piddy MR2 Forum 20 02-07-2005 05:22 PM
98 corolla ? stock ? what mods to do ccmextreme Archived Corolla threads 2 07-16-2004 11:55 PM
