7M-GE bearings ? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-13-2007, 08:29 PM   #1 (permalink)
View newtosupras's Photo Gallery
7M-GE bearings ?
i bought a 89 supra about 4 mths ago with a rod knock. I heard I could drop the oil pan and and change bearings that way. From experience is this possible and are there potentially any risks? Ido understand that its probably best to do the bottom end but Ireally dont have the money. I will have some help but neither of us are familiar with the 7m-ge. any suggestions?
newtosupras is offline   Reply With Quote
Old 07-13-2007, 08:51 PM   #2 (permalink)
View toyomoho's Photo Gallery
The rod bearing will only get worse over time; the result could be a thrown rod. If the crank journal has been damaged from all the pounding, just replacing the bearing will not solve the problem. Then the crank needs to be repaired or replaced.
Old 07-14-2007, 01:59 PM   #3 (permalink)
one turbo is one too few
bgrieger's Avatar
Gameroom cash: $309050
View bgrieger's Photo Gallery
You will also have the fight of your life trying to do bearings in the car. There is not enough clearance to remove the pan while the engine is bolted in. Some who have done it had to lift the engine a few inches to get clearance to remove the pan and swore they would never do it again for any amount of money.
Old 07-16-2007, 02:22 PM   #4 (permalink)
Got Hardass?
Jeeves's Avatar
View Jeeves's Photo Gallery
I've removed the pan with the engine in the vehicle. I had to lift the engine, and drop the crossmember and I still didn't have lots of room.
Old 07-17-2007, 10:46 AM   #5 (permalink)
View jsbenami's Photo Gallery
Get a used motor. Probably cheaper, definitely less hassle. Ebay is your friend. If your rods are in sham shape, then there is not much point to repair it. Also take into consideration it's mileage.
jsbenami is offline   Reply With Quote
Front Wheel bearings ronho56 2nd Generation (2005+) 17 01-03-2008 02:52 PM
Can I press in Strut bearings ? mxsurf Camry & Solara Lounge 3 08-31-2006 06:40 PM
Rod Bearings and Window....>.< importdriver007 Camry & Solara Lounge 0 11-28-2005 09:40 PM
7m ge non turbo injector levarg Camry & Solara Lounge 3 04-23-2003 05:27 PM
3s-fe with GE head? crazy_camry Camry & Solara Lounge 3 12-24-2002 06:08 AM
