7M to 2JZGTE swap. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-21-2007, 04:53 PM   #1 (permalink)
View jon_570's Photo Gallery
7M to 2JZGTE swap.
whos taken the old 7mgte out and replaced it with a 2jzgte manual. does the r154 trans work with the 2jz or can i use the 2jz tranny? how about engine mounts. is it exact or is there some cutting and welding required. im thinking of just throwing out my old 7m sometime and getting a 2jz
jon_570 is offline   Reply With Quote
Old 07-21-2007, 08:32 PM   #2 (permalink)
one turbo is one too few
bgrieger's Avatar
Gameroom cash: $309050
View bgrieger's Photo Gallery
R154 requires a 1j bell housing to mount to any JZ engine. You can use the getrag if you have it, but there is cutting welding and the shifter sits about 4 inches back from where it should be.
JZ engines require 89+ subframes, or adapters to fit an 86.5-88.
Old 07-21-2007, 11:54 PM   #3 (permalink)
Toyota Apprentice
Bimmer's Avatar
View Bimmer's Photo Gallery
Yeah if you want to do it yourself you have to find some good reads on it.
I may be doing it with my supra next year but not this year since I'm getting new wheels.
I'm sticking with the R154 only becasue I don't want to have to buy a Getrag :p
I work for Toyota and like Toyota but I'll always be a BMW fan
Bimmer is offline   Reply With Quote
Old 07-22-2007, 12:00 AM   #4 (permalink)
Offical TN Hillbilly
TcmaBoy's Avatar
View TcmaBoy's Photo Gallery
The R154 takes the 1JZ bell housing and flywheel with the 7MGTE clutch and starter. For motor mounts you need the 89+ sub frame with the corresponding round motor mounts and the 1JZ engine brackets.
Don't you SAS me boy.
Please wheel responsibly.
TcmaBoy is offline   Reply With Quote
Old 07-22-2007, 12:22 PM   #5 (permalink)
so will the 89 subframe fit onto the 87's or no?
Old 07-22-2007, 07:34 PM   #6 (permalink)
I Bleed TRD
willtotheumm's Avatar
View willtotheumm's Photo Gallery
isn't replacing the subframe...tricky? I can imagine it's quite involved...
any estimates as to how much the 1jz bell housing costs or where I could find it? I'm wanting to do this swap, I just haven't looked too into it as I cant afford it for several months...
1988 Supra Turbo- Stock 7M-GTE, 5-speed manual, HKS Turbo timer, ARP headstuds, planning 2jz-gte swap
1988 MR2- Stock 4a-ge, 5-speed manual, planning 20v swap
My Cardomain / My Myspace
willtotheumm is offline   Reply With Quote
Old 07-22-2007, 07:35 PM   #7 (permalink)
bgrieger's Avatar
In terms of an engine swap, a subframe swap is a joke. Once the engine is out, the subframe and suspension is +/- a dozen or so bolts and out it goes. Hell, if youre creative and have a hoist, you can leave the engine in and drop it all out the bottom.
Old 07-22-2007, 07:52 PM   #8 (permalink)
^ are you saying its a joke as in real simple..seems like thats what youre saying
Old 07-22-2007, 07:59 PM   #9 (permalink)
I Bleed TRD
I sure hope so LOL. Im gonna look more into that. And more importantly... where to find an 89+ subframe lol
Old 07-22-2007, 09:19 PM   #10 (permalink)
That Acura Guy
TTercel's Avatar
Gameroom cash: $267565
View TTercel's Photo Gallery
Hmmm, why go through all the trouble and money to put in a 2JZ in, when you can modify the 7M. Yes it has a lot of bad credabilty but its an awesome motor once get rid of the freaky BHG problems...
TTercel is offline   Reply With Quote
Old 07-22-2007, 09:59 PM   #11 (permalink)
idk..well either way im getting a new motor for it w/e way i go.. but a 2JZGTE is way more unique in this car..
Old 07-22-2007, 10:00 PM   #12 (permalink)
if i keep the 7m im going to be aiming for a good 450-500hp..if i use the j2z i might go for maybe like 600 or so..idk yet
Old 07-23-2007, 10:44 AM   #13 (permalink)
bgrieger's Avatar
If you can swap an engine, the subframe is a joke...if you're tools haven't seen a bolt yet, it's probably not going to be fun or easy. You'll require a hoist or several jacks and in either case stands to support the frame. Really, it's like 12 nuts and bolts to drop it once you have the engine removed and the various lines (brake, power steering etc).
Old 07-23-2007, 11:34 AM   #14 (permalink)
k
thanks
Old 07-24-2007, 02:37 PM   #15 (permalink)
I Bleed TRD
any chance of warping the frame by not supporting it properly?
oh and I already found an 89+ subframe hahah. Still has the 7m in it though. I take it you have to take the engine out first? It's in a junkyard... car wasn't totalled just the idiot ran it without oil heh.
3sgte swap into a 2.2 NA MR2 pdxvento MR2 Forum 12 03-28-2007 11:59 PM
1993 gs300 2jzgte swap jdmaddiction General Lexus Discussion 0 10-27-2005 08:58 PM
4agze w/auto swap ? SuperV Archived Corolla threads 0 02-13-2004 01:29 PM
4A-GZE Swap - More Details? clumzy Archived Corolla threads 8 08-31-2002 12:02 PM
