wiring Apexi S-AFC for my 7MGTE - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-27-2007, 11:22 PM   #1 (permalink)
UNATUL APIRTED's Avatar
View UNATUL APIRTED's Photo Gallery
3rd Generation wiring Apexi S-AFC for my 7MGTE
hi i am just having some troubles hooking up my Apexi S-AFC unit into my car. I have a 87 Supra 7MGTE. i have talked to a couple people about the wiring and also called apexi themselves but no luck yet on getting power to the unit. I have tested the unit with a jumper wire and the buttons did light up but the screen did not display like i have seen in other units when turned on. also wondering if anyone knows the exact color code for the wires on this?
UNATUL APIRTED is offline   Reply With Quote
Old 07-30-2007, 01:04 AM   #2 (permalink)
Got Hardass?
Jeeves's Avatar
View Jeeves's Photo Gallery
Did you look at Apexi's site? They have all the original manuals there.
http://www.apexi-usa.com/pdfWiring/7.pdf
http://www.apexi-usa.com/support_installation.asp
Old 07-30-2007, 01:11 PM   #3 (permalink)
yeah i have looked at it many times!! do you know if they display should come on when i hard wired the unit to turn it on??
Old 07-30-2007, 08:02 PM   #4 (permalink)
Got Hardass?
Jeeves's Avatar
I think if you give it power, it should power up. Make sure however that you're using both grounds (there are two on the SAFC-II, can't vouch for the SAFC-I) and such.
Old 07-31-2007, 12:24 AM   #5 (permalink)
i definetly should have power. i wired my ign wire straight to my wire under my steering columb. and i also have power at the big connector which goes to the unit. i also have both grounds set up as they should be. the brown on closest to the ecu and the black one probly more than an inch torward the firewall on the same ground wire??
Old 07-31-2007, 09:14 AM   #6 (permalink)
Got Hardass?
Jeeves's Avatar
Sounds like your AFC doesn't work.
Old 07-31-2007, 02:40 PM   #7 (permalink)
yeah that is what i was thinking. just was wondering if anyone had any input on the subject if you have hooked one up in a supra! thanks for the help!
4AGE swap 1992corolla 6th Generation (1988-1992) 26 09-11-2010 11:48 AM
90-92 7mgte wiring harness 88suprafast1 Supra Forum 2 08-09-2006 02:35 PM
Wiring Diagram to install Apexi SAFC 2 Rapeacivic Camry & Solara Lounge 1 11-16-2004 02:23 PM
apexi afc chashowlett MR2 Forum 0 08-07-2004 04:17 AM
AFC Wiring Dio for 1998 Camry CE RIPPMODS 3rd & 4th Generation (1992–1996 & 1997–2001) 0 07-30-2003 02:31 PM
