can you use carb cleaner instead of intake/throttle body cleaner on fuel injected cars or will it harm parts of the cars sensors, what is the difference between carb/choke cleaner and air intake/throttle body cleaner. and my last question is I heard you can clean the pistons, valves, and throttle body if you spray the cleaner in a vaccume hose while the car is running at 2000 rpms is this true, and does it matter what hose you disconect to do this or is it any vaccume hose
There is a product out there called Sea Foam that will clean the combustion chamber. You hook it to a vac line on the intake and let it draw the stuff in.
Don't you SAS me boy.
Please wheel responsibly.
Which vacuum hose do you hook it up to?
__________________ Wanted: Toyota Back-up camera - Video Rearview Mirror - Air Bag for MR-S or Celica GT-S Steering Wheel
1) Pour 1 cup of Seafoam into a plastic cup.
2) Remove brake booster line (separate it at the connector on the firewall, and use the hose itself to suck up the fluid)
3) Having someone keeping on the gas a little bit, allow the brake booster line to suck up all the seafoam.
4) Once the cup is dry, turn OFF the car.
4b) Re-attach the brake boster line.
5) Let it sit for 5 minutes or so.
6) Start 'er back up and drive around for 15 minutes. You'll smoke for a good period of time, but it's just burning out everything. Nothing's broken.
And that's it
