Starter relay location - 1987 Turbo? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-06-2007, 08:10 AM   #1 (permalink)
View ToyFan420's Photo Gallery
Question Starter relay location - 1987 Turbo?
My Dad just shipped me his '87 Turbo 5 sp (original owner) for my next project car. When I went to pick it up at the terminal, it wouldn't start. Funny, because it drove right on the truck. Oh well. No click, no nothing. So after a $250 tow home, I found that the starter and solenoid were fine, after hooking a jumper from the battery to the smaller (ignition switch) terminal on the starter.
Where is the starter relay located on this model? My Haynes manual really doesn't shed much light on this subject. Is there a way to test the relay? Does anybody know what terminal to check to see that the ignition switch is sending juice to the relay? Thanks!
ToyFan420 is offline   Reply With Quote
Old 08-06-2007, 11:25 AM   #2 (permalink)
Got Hardass?
Jeeves's Avatar
View Jeeves's Photo Gallery
No Click, No nothing. Are you sure it's not the alarm? The factory alarm will disable the starter and you must reset it before it'll kick.
Old 08-06-2007, 06:03 PM   #3 (permalink)
Funny you should mention that. It had an intermittent problem with the alarm arming itself, so the last shop that worked on it pulled the harness to the alarm brain. When I received the car, that was one of the first things my Dad mentioned.
To make a long story short, I guess the shop had jumpered a ground wire to the security system harness, and it had fallen out as the car was trucked up north. I ended up just making a little harness for the starter relay itself and manually grounding terminal #3. They had just rigged it... ...and done a poor job. This may be, however, a useful piece of info for someone whose OEM security system acts up. I don't want to see another test light or wiring schematic for at least a few weeks...
5s-fe turbo install list R94CamryT Hardcore Tech and Competition 32 04-29-2009 01:37 AM
Fairly Comprehensive factory 0-60 times under 6 sec. Rdizzle General Discussion 15 04-09-2007 10:12 PM
Testing the starter relay? sanfelice Camry & Solara Lounge 3 06-04-2006 12:13 PM
1987 supra turbo value kgizzle1 Supra Forum 2 10-04-2005 08:12 PM
Does a 1987 turbo radiator fit on a 1987 n/a??????????? romors666 Supra Forum 5 08-27-2005 03:07 AM
