2jzge - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-13-2007, 11:54 PM   #1 (permalink)
View suprabran's Photo Gallery
2jzge
how hard would it be to swap a 93 and up 2jzge non turbo engine in a 88 supra. could I keep the tems system or not, and how much wiiring would it be, and is the supra 2jzge engine the same in the gs300 lexus and the sc300 or is there some differences,
suprabran is offline   Reply With Quote
Old 08-13-2007, 11:56 PM   #2 (permalink)
i have a friend that is going to part out a gs300 so I just was woundering how much trouble will I get my self into, and what transmission should I look into getting the gs300 is automatic and my supra is manual and I would rather keep it this way if I can
Old 08-14-2007, 12:20 AM   #3 (permalink)
Offical TN Hillbilly
TcmaBoy's Avatar
View TcmaBoy's Photo Gallery
You are going to have to change out the front sub frame for an 89+, get new motor mounts, get a R-154 trans with bell housing, a fly wheel, a clutch, cheat the ECU so that it will start and run with no auto trans hooked up......it goes on and on.
The real question is are you ready and willing to spend the money and do the work?
Don't you SAS me boy.
Please wheel responsibly.
TcmaBoy is offline   Reply With Quote
Old 08-14-2007, 04:17 PM   #4 (permalink)
Got Hardass?
Jeeves's Avatar
View Jeeves's Photo Gallery
I don't see the gain personally, but hey, if you've got one for free that's an easy start.
Old 08-14-2007, 04:54 PM   #5 (permalink)
thanks guys I just wanted to know how much work, I thought if it was just a engine transmission swap I would, but I didnt think it would be this difficult
Old 08-18-2007, 03:41 PM   #6 (permalink)
I Bleed TRD
willtotheumm's Avatar
View willtotheumm's Photo Gallery
it's gonna take some work dude. like Tcmaboy said.. are you willing?
1988 Supra Turbo- Stock 7M-GTE, 5-speed manual, HKS Turbo timer, ARP headstuds, planning 2jz-gte swap
1988 MR2- Stock 4a-ge, 5-speed manual, planning 20v swap
My Cardomain / My Myspace
willtotheumm is offline   Reply With Quote
Old 08-18-2007, 10:30 PM   #7 (permalink)
no Im probally going to build back up my 7mge thats got a thrown rod. but I might do a swap if something out there is cheaper. does any one know if the mulit lared head gaskets are good at ebay I have heard some good stuff but will they hold boost if I turbo charge it in the future
Old 08-20-2007, 02:12 PM   #8 (permalink)
Got Hardass?
Jeeves's Avatar
If you're going to turbo it, you should really just cut the foreplay and swap in a 7M-GTE, with a machined block, machined head, metal head gasket and ARP head studs.
Old 08-20-2007, 05:37 PM   #9 (permalink)
do you think it would be easier to just swap engines, could you use the same ecu and wiring harness or not, what would be required to make the car run with a 7mgte swap
Old 08-20-2007, 06:35 PM   #10 (permalink)
Got Hardass?
Jeeves's Avatar
Depends on how you want to do it. This is a long post, so rather than copy it verbatim, here's the link:
http://www.supramania.com/forums/showthread.php?t=27725
There are very few straight, simple swaps like that. However, it's simpler than swapping into a whole other engine.
Old 08-20-2007, 08:13 PM   #11 (permalink)
thanks alot for the link he said you could use the w58 non turbo transmission is this true if so I can save alittle money
Old 08-20-2007, 09:03 PM   #12 (permalink)
one turbo is one too few
bgrieger's Avatar
Gameroom cash: $309050
View bgrieger's Photo Gallery
up to a point. It depends how much power you want to run. Cross into the high 300's and I'd have enough money around to pick up an R154 for when the W58 lets go. Some get good life out of them, many do not. The R154 is a much more resilient gearbox should you enjoy drag racing or you head for real high HP
Old 08-20-2007, 09:33 PM   #13 (permalink)
so will the w58 transmission bolt up to the 7mgte engine with out any modifications or fabrications
Old 08-21-2007, 08:53 AM   #14 (permalink)
bgrieger's Avatar
if you have a 7m bell housing it will bolt to either the gte or the ge
Old 08-21-2007, 03:50 PM   #15 (permalink)
thanks alot guys for all the help Im sorry I have so many questions
2jzgte vs 2jzge rice Supra Forum 1 04-18-2006 11:59 PM
Bosch Platinum 2 Plugs with 2JZGE engine furballi General Discussion 6 09-03-2005 07:52 AM
2jzge -> 1jzgte d0rid0rk General Lexus Discussion 10 03-09-2004 12:20 AM
2JZGE info/powerup/help me leonard e Supra Forum 12 02-05-2004 04:22 PM
