7mgte idle problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-03-2007, 03:15 PM   #1 (permalink)
View MAG.net's Photo Gallery
7mgte idle problem
ok so i have a problem with my idle, it fluxtuates up and down with no gas applied. i was told by a friend that it could be a vaccum leak but i'm not sure and i wouldnt know where to look first! pls help i was also told that it could be my iac. any suggestions? thanks in advanced!!
MAG.net is offline   Reply With Quote
Old 09-03-2007, 06:54 PM   #2 (permalink)
one turbo is one too few
bgrieger's Avatar
Gameroom cash: $309050
View bgrieger's Photo Gallery
Idle up and down is the IAC doing it's job. The computer is seeing too much fuel, then not enough and opening and closing the valve to try to compensate for the air it sees going through the meter. It likely is a leak, and vacuum is one source as good as any to start with. Also, any connections post air flow meter is another thing to look into. Finally, if there is nothing else, you get into intake manifold and throttle body gaskets, or actual leaks from damage to pipes and the intercooler. Had anything apart recently?
88 celica idle problem fkruger35601 Celica Forum 0 07-01-2007 10:21 PM
Please Help Solve My Idle Problem! coooray 89-95 Toyota Pickup/Hilux 18 04-06-2007 12:22 AM
93 3VZ-FE idle problem while in gear wallyj 3rd & 4th Generation (1992–1996 & 1997–2001) 12 09-15-2006 08:35 AM
IdLE PROBLEM ZIXXER 1st Generation (1995.5–2004) 2 12-07-2005 06:47 AM
88 Camry - Idle problem after a hard stint JetspeedCamry 1st & 2nd Generation (1983–1986 & 1987-1991) 3 10-24-2004 11:15 AM
