Swapping in the GTE from the same year car is far easier than turboing an NA motor. For a swap, you literally gut the engine bay from one, put the parts in from a doner car and swap the ECU. Granted, you can use the CT26 and manifold on the NA, which puts you light years ahead of building from scratch, but there are a number of little things to overcome you don't need to with a straight swap of the whole works.
If you don't have the knowledge to swap an engine, don't even consider boosting one...unless you're made of cash and want to keep replacing things until you get it right...Keep reading, here and supramania.com for good swap info. Don't bother asking "how do I swap" on supramania unless you want to get flamed into next year...read...be a sponge until you understand the basics. They have a swap and a turbo/na section.
That said, since the chassis are the same, you already know every part from a turbo car will fit in an NA car, and vice versa. Its a start...
