86.5 Oil Pressure Guage - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-05-2007, 02:43 AM   #1 (permalink)
View 86SupraMan's Photo Gallery
i got my 86.5 supra recently, and ive decided to swap the engine as it has a blown wrist pin on a cylander, but im wondering if anyone could tell me, what should the oil pressure guage should be reading "normally", also could somone tell me what is the octane level fuel i should be putting in, somehow i doubt 86 octane would cut it for this car,
Thanks for any info
86SupraMan is offline   Reply With Quote
Old 09-05-2007, 03:21 AM   #2 (permalink)
View jon_570's Photo Gallery
the fuel pressure on the turbo is allowed to drop semi low at idle.. but while driving it should be between about 35 and 80 PSI as so says my manual for my 1987 supra.. this is the 7mgte engine also...
if you have the turbo i would put 89 octane in it... you dont want it to detonate and all a fuel octane rating is, is its resistance to detonation. the higher the number the higher its resistance
jon_570 is offline   Reply With Quote
Old 09-05-2007, 07:47 AM   #3 (permalink)
one turbo is one too few
bgrieger's Avatar
Gameroom cash: $309050
View bgrieger's Photo Gallery
The 86.5 was not a factory turbo, so I'll assume yours isn't.
Oil pressure is about as stated. Don't be too surprised when it bottoms out at idle.
Fuel: good old regular will do. I would run higher octane myself in a turbo car as the computer will pull timing out and you don't get all the horses, and I would certainly do it on a modified car, but it will make it from one place to another on the cheaper stuff. A good economy tip: if you're making a long distance highway drive and staying out of the boost, step down the octane of fuel you will burn on the way, then octane up when you get there. We frequently drive to Kentucky and other meets, normally a 2 fill up drive, and since we're just cruising, I would go this route to save a little cash.
Old 09-05-2007, 08:32 AM   #4 (permalink)
yea, mine is N/A but my oil pressure guage reads about 2psi (i think its measured as psi, need to check to be sure) of pressure, i was wonderin if this is normal
Old 09-05-2007, 12:04 PM   #5 (permalink)
thats low...theres many things that can cause low oil pressure...worn journal bearings for one..is your oil full and the filter working right?
Old 09-06-2007, 02:42 AM   #6 (permalink)
CRE
View CRE's Photo Gallery
Check the connection at the pressure sender as well. It's possible that you're getting a false reading. It's also possible that the sender is faulty or clogged.
CRE is offline   Reply With Quote
Old 09-07-2007, 01:30 PM   #7 (permalink)
7MGTE/22RE
shaeff's Avatar
View shaeff's Photo Gallery
and keep in mind that the 7m uses a high volume, low pressure oil system. many perfectly running 7m's will bottom out the OP gauge (read: zero) at idle.
-shaeff
My heater core replacement writeup with pics: http://www.toyotanation.com/forum/t209136.html
1994 Toyota 4x4, 31x10.50, 22re. <- to undergo high compression 7MGTE swap whenever i finish building it.
1986.5 Toyota Supra- 300+rwhp. (capable of over 400, but i haven't tuned it yet)
shaeff is offline   Reply With Quote
OBDII codes Phi Hardcore Tech and Competition 12 12-24-2011 09:38 AM
WTF! 2007 Camry SE Only Giving Me 263.7 mi WITH Full Tank! LunarMist 5th & 6th Generation (2002-2006 & 2007-2011) 262 01-15-2011 01:17 PM
5s-fe turbo install list R94CamryT Hardcore Tech and Competition 32 04-29-2009 01:37 AM
Oil Changes for Dummies Peter Off Topic 20 01-04-2006 04:32 AM
1990 N/A Auto :( dave_id Supra Forum 6 08-26-2004 12:18 PM
