gasoline! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-07-2007, 02:15 PM   #1 (permalink)
View ebolabar's Photo Gallery
gasoline!
hey guys,
Is premium fuel reccommended or REQUIRED for mk3's? I would like to keep using regular gas but not if it's going to hurt my car
ebolabar is offline   Reply With Quote
Old 09-07-2007, 02:24 PM   #2 (permalink)
View jon_570's Photo Gallery
i think it says 87 is fine but it recommends using at least 89...i use 89.. and ill use it till i start modding
jon_570 is offline   Reply With Quote
Old 09-07-2007, 02:58 PM   #3 (permalink)
CRE
View CRE's Photo Gallery
Depends entirely on how you drive, climate (humidity and air temp), altitude and if the engine's running stock or not. For the average driver I recommend using the lowest grade you can without the car feeling hesitant or like it's missing at higher RPM.
CRE is offline   Reply With Quote
Old 09-07-2007, 06:51 PM   #4 (permalink)
I Bleed TRD
willtotheumm's Avatar
View willtotheumm's Photo Gallery
103 octane and nothing less!!!!
well...actually my Supra doesnt even run at the moment so... yeah hahah. 0 octane FTW!
1988 Supra Turbo- Stock 7M-GTE, 5-speed manual, HKS Turbo timer, ARP headstuds, planning 2jz-gte swap
1988 MR2- Stock 4a-ge, 5-speed manual, planning 20v swap
My Cardomain / My Myspace
willtotheumm is offline   Reply With Quote
Old 09-07-2007, 09:19 PM   #5 (permalink)
7MGTE/22RE
shaeff's Avatar
View shaeff's Photo Gallery
i hope your car is very modified, otherwise you'll be slower than a car with similar modifications.
so many people think that a higher octane rating will net you more power, which is entirely untrue.
CRE is right on. use the lowest octane possible without pinging. (or feeling a noticable decrease in power due to the timing being pulled)
93 octane fuel burns SLOWER than 87 octane. you want to use high octane fuel with a high compression motor, whether it be a high static CR, supercharged, or turbocharged.
now, just because you're turbocharged doesn't mean that you automatically need 93 octane. if you're stock, you could probably get away with 87, but might experience pinging on a hot day. a safer bet would be 89. i ran 89 on my car for quite a while at stock boost levels.
once i started running 15psi, i went to 93 octane. so many people overlook octane ratings, but there's power to be made simply in the fuel you use. take advantage of the cheap fuel, and more power! especially if you have a stock motor!
-shaeff
My heater core replacement writeup with pics: http://www.toyotanation.com/forum/t209136.html
1994 Toyota 4x4, 31x10.50, 22re. <- to undergo high compression 7MGTE swap whenever i finish building it.
1986.5 Toyota Supra- 300+rwhp. (capable of over 400, but i haven't tuned it yet)
shaeff is offline   Reply With Quote
Old 09-07-2007, 09:38 PM   #6 (permalink)
CRE
Thanks for posting that Shaeff... i get so sick of trying to fight all the bad info out there sometimes and I really didn't want to cover that one again.
Old 09-07-2007, 09:46 PM   #7 (permalink)
7MGTE/22RE
shaeff's Avatar
no problem, man.
-shaeff
Old 09-08-2007, 12:43 AM   #8 (permalink)
the fuel rating is really just the resistance the gas has to detonation.
Old 09-08-2007, 01:44 AM   #9 (permalink)
CRE
Or how long it takes to burn.... It's not just a matter of detonation. Running too high of an octane can result in higher EGT, O2 sensor damage, power loss and in some extreme cases burnt valves.
Old 09-08-2007, 03:21 AM   #10 (permalink)
^^ it realy cant damage the o2 sensor unless you got some WAY SHITTY fuel... or youre running SUPER SUPER rich..
even then. the o2 sensor wont get hurt from what octane you use.
Old 09-08-2007, 03:52 AM   #11 (permalink)
CRE
Bud, I've got an O2 sensor that's going to cost me $100 to replace because the stock location is simply too hot at stock timing.... take my word on this one. I didn't say it was common, but it does happen. The only reason I didn't have HUGE problems is thanks to a massive timing advance which brings down my EGTs greatly.
The reason for the increase in EGTs is quite obvious and O2 sensors have a limited operational temperature range and lifespan (a factor of which being the temperature range they're typically exposed to).
Old 09-08-2007, 11:41 AM   #12 (permalink)
Offical TN Hillbilly
TcmaBoy's Avatar
View TcmaBoy's Photo Gallery
It sounds like you have a lean out problem.
Don't you SAS me boy.
Please wheel responsibly.
TcmaBoy is offline   Reply With Quote
Old 09-08-2007, 03:02 PM   #13 (permalink)
CRE
Nope.
Regardless, you guys are missing the point. Even one grade of gas can mean a big difference in your EGT. The gas was still burning that much closer to the time that the valves opened and as little as a couple ns can mean enough of a temperature increase at high RPM to shorten the service life of certain components drastically. The relationship is much like the one between EGT and ignition advance.
I wasn't trying to say that it was extremely common, happens often, will happen from going up just one grade higher than you need, or that it would result in instant death. My statement did come off as a bit final but I was just trying to make a point.
As for my own issue, that occured for a couple different reasons.
What octane you guys running with the V-6? Joe B 5th & 6th Generation (2002-2006 & 2007-2011) 64 03-04-2007 05:36 PM
2jz-gtte Jmac279 Supra Forum 30 02-02-2007 12:54 AM
Supra Specs and time frames? glish_dreams Supra Forum 17 04-17-2006 11:14 PM
gasoline smell in engine bay Redline Camry & Solara Lounge 4 03-29-2006 01:05 PM
What your gasoline is really doing to your engine Ratko General Discussion 25 04-05-2005 10:06 PM
