Cranks - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-10-2007, 11:29 AM   #1 (permalink)
View twentybinders's Photo Gallery
Cranks
Does anyone on here have a good 88 7mgte crank and rods for sale?
Or knows anyone or a place that sells one?
twentybinders is offline   Reply With Quote
Old 09-10-2007, 04:27 PM   #2 (permalink)
7MGTE/22RE
shaeff's Avatar
View shaeff's Photo Gallery
i would think carefully when deciding which crank to use. early (pre '89) 7M's use a 6M crank, and mid '89+ 7M's use a 7M crank.
the 7m is a much smoother crank, as it has more counterbalances.
-shaeff
My heater core replacement writeup with pics: http://www.toyotanation.com/forum/t209136.html
1994 Toyota 4x4, 31x10.50, 22re. <- to undergo high compression 7MGTE swap whenever i finish building it.
1986.5 Toyota Supra- 300+rwhp. (capable of over 400, but i haven't tuned it yet)
shaeff is offline   Reply With Quote
Old 09-10-2007, 04:30 PM   #3 (permalink)
is that what they use stock? I don't know much about the internals of the motor.
Is the 6m crank best to use for the 7MGTE?
All I really need is a crank to make my car driveable. I need it desperatly
Old 09-10-2007, 04:55 PM   #4 (permalink)
7MGTE/22RE
shaeff's Avatar
both the 6M and 7M crank came in the 7mgte. if your car is an '88, then it came with the 6M crank.
if you're just wanting to make your car drivable, either will work, but the 7M crank will give a smoother feeling motor than the 6M.
-shaeff
Old 09-10-2007, 04:56 PM   #5 (permalink)
sounds good. so either crank should just fit right in then
Old 09-10-2007, 06:16 PM   #6 (permalink)
CRE
View CRE's Photo Gallery
Well, you'll need to check clearances and possibly replace bearings... but yes, either one will fit and run fine.
On a side note the 89 and later MKIIIs had a lower redline (6250, reduced from 6500 with the 6M crank) due to the additional weight and rotating mass of the 7M crank.
CRE is offline   Reply With Quote
Old 09-10-2007, 06:18 PM   #7 (permalink)
Yesh, You guys are on like every supra forum!!
I have an 88 turbo supra if I didn't mention that before..
Does it matter if the crank is from an NA or Turbo car motor?
Old 09-10-2007, 06:21 PM   #8 (permalink)
CRE
Hehe... yes, Shaeff does get around, doesn't he?
The 7M-GE and the 7M-GTE use the same crank... no worries there.
Old 09-10-2007, 06:22 PM   #9 (permalink)
Hahaha!!
You two run these forums man.
You guys are really know these cars well. I envy you both.
Old 09-10-2007, 07:31 PM   #10 (permalink)
CRE
Well, thanks. No need for envy though... the only reason i know mine so well is that it's always falling apart.
Old 09-10-2007, 08:13 PM   #11 (permalink)
Learn by doing, learn by doing.
Old 09-10-2007, 08:28 PM   #12 (permalink)
7MGTE/22RE
shaeff's Avatar
exactly. no need for envy! once your car starts falling apart, you'll know more, too! haha
(honestly though, i used: i-supra.com, supramania.com, supraforums.com, and 4cefed.com as read-only for almost two full years before i made a single post. all the info is out there, you just have to really search to find some of it!
i'm just trying to give back all the info that i've taken!
-shaeff
Old 09-10-2007, 08:29 PM   #13 (permalink)
Yeah I'm on all of those. You and I exchanged posts on i-supra before.
Never hear of 4cefed before.
Old 09-11-2007, 01:43 AM   #14 (permalink)
Got Hardass?
Jeeves's Avatar
View Jeeves's Photo Gallery
Isn't that the truth.
Ugh.
Old 09-11-2007, 01:50 AM   #15 (permalink)
CRE
Oh yeah. If not for the fact that I can't get a break from the car I'd have been stuck by the roadside tonight.
The car started bucking whenever I was at a low throttle position... turns out the connector for my TPS cracked in several places and worked it's way loose. Heh, two years ago I would have absolutely freaked.
New Cranks Toyotalicious Car Parts for Sale 0 12-29-2006 12:59 PM
How many cranks till engine starts? zettahertz 5th & 6th Generation (2002-2006 & 2007-2011) 18 09-06-2006 02:11 AM
93 camry cranks continuously, won't fire magicteeto 3rd & 4th Generation (1992–1996 & 1997–2001) 13 05-16-2006 01:28 AM
Car cranks but won't start? sleepie Archived Corolla threads 13 12-28-2005 05:42 PM
Swapped battery terminals - now engine cranks but doesn't start...what have I broken? dolphan Camry & Solara Lounge 5 08-18-2005 09:27 AM
