Stock Boost - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-13-2007, 10:43 PM   #1 (permalink)
Vroom!
supranites90's Avatar
View supranites90's Photo Gallery
3rd Generation Stock Boost
How much boost can a stock 90 supra turbo hold without engine upgrades? FYI my engine is in pretty good condition although i might get the head gasket replaced w/ a metal one if i can find it...but without that...i wonder...
supranites90 is offline   Reply With Quote
Old 09-13-2007, 11:13 PM   #2 (permalink)
CRE
View CRE's Photo Gallery
How much boost on what turbo? Pressure is only one half of the equation.
On a stock composite HG 12 - 14psi with a slightly upgraded ct-26, provided it's not the ORIGINAL HG installed at the ORIGINAL torque specification... if it is it'll hold 12 - 14 for about 10 minutes to one week.
CRE is offline   Reply With Quote
Old 09-14-2007, 12:26 AM   #3 (permalink)
Got Hardass?
Jeeves's Avatar
View Jeeves's Photo Gallery
Flow? Who needs flow, pfft.
IMO, 10psi is about tops for 'daily drivability' on the stock HG, and even then it's way more than likely to go on you. Hell, running stock boost on a stock torqued HG is dangerous ;-)
Old 09-14-2007, 12:35 AM   #4 (permalink)
CRE
Heh, he never asked how long it would last.
It would really depend on the driver too... in my case I'd give a stock HG with ARPs and 72ft lbs about 2 years. Half my friends would kill it in less and it would probably last my wife another 17 years.
Running stock boost on a stock HG isn't just dangerous... It's downright boring.
Old 09-14-2007, 08:59 AM   #5 (permalink)
Vroom!
ok...well my turbo is still the stock one bc i have no funds at the moment for upgrades....but i might be able to afford a new headgasket soon....so it should be able to handle about 10 psi with a metal gasket on the stock turbo right?
Old 09-15-2007, 05:16 PM   #6 (permalink)
I Bleed TRD
willtotheumm's Avatar
View willtotheumm's Photo Gallery
funniest shit i've heard all week
1988 Supra Turbo- Stock 7M-GTE, 5-speed manual, HKS Turbo timer, ARP headstuds, planning 2jz-gte swap
1988 MR2- Stock 4a-ge, 5-speed manual, planning 20v swap
My Cardomain / My Myspace
willtotheumm is offline   Reply With Quote
Old 09-15-2007, 07:07 PM   #7 (permalink)
Got Hardass?
Jeeves's Avatar
You can't just install a metal gasket and be good. You have to machine the block and head as well or the metal head gasket is really all for naught.
Old 09-16-2007, 05:41 PM   #8 (permalink)
Vroom!
ok...upgrade the whole damn thing...got it =D
Old 09-16-2007, 06:35 PM   #9 (permalink)
View jon_570's Photo Gallery
so...when i had my HG changed i had a stocker placed back in and was torqued to 75 foot pounds.. been running 6 pounds of boost.. when they had the had off you could still see the cross hatching in the cylinder which was GREAT for a 100,000 mile motor. but if i shim the wastegate to 10 psi how long would it last in actuality... i mean im not in boost ALL the time.. only really to go up hills when i downshift or for the most like 5-10 seconds at most at a time..
jon_570 is offline   Reply With Quote
Old 09-16-2007, 09:38 PM   #10 (permalink)
CRE
Have a thorough leak down test done to determine the state of the rings. I'd also recommend using an actual boost controller, it makes it a lot easier to dial in a lower level if needed.
Old 09-16-2007, 09:53 PM   #11 (permalink)
i can control the boost level with my foot.. i dont street race.. so if i see boost creep or anything ill let off the gas. whe i drive down and i floor it itll go to 6 pounds but if i let off a lil itll go down to 4.. expected.. i dont need a boost controller till i start modding and rebuild the motor
More Whiteline anit-swaybar questions: How many washers for stock caster? nogard 1st & 2nd Generation (1983–1986 & 1987-1991) 3 01-12-2007 08:06 PM
How many boost has a stock 87 turbo supra? Celica3SGTE Supra Forum 1 08-22-2005 12:38 AM
Safe 7 psi boost on the 1MZ-FE SuperSolara Camry & Solara Lounge 1 04-01-2004 02:24 PM
Stock Boost on JDM Celica 3sgte? IMPORTMyth01 Celica Forum 3 03-24-2004 07:38 AM
WHATS THE STOCK BOOST ON A 91 Turbo? PoObAa MR2 Forum 3 11-23-2002 07:47 PM
