shim the wastegate - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-19-2007, 12:50 PM   #1 (permalink)
View jon_570's Photo Gallery
shim the wastegate
im going to be shimming my wastegate today with 4 washers.. i know 5 gets you upto 10psi but im only puttin 4 on... what size do they need to be.. i know its like 2mm think but i mean the hole for the bolt..how big should it be? Thanks
jon_570 is offline   Reply With Quote
Old 09-19-2007, 12:54 PM   #2 (permalink)
one turbo is one too few
bgrieger's Avatar
Gameroom cash: $309050
View bgrieger's Photo Gallery
There is no defined formula for washers. Put 4 on and see where you are. If you want more, or hit fuel cut, add or remove as required. Have you upgraded the exhaust? If not, don't expect it to be able to hold more than 10 or so to redline due to restriction at higher RPM, and if you do hit more than 10 by 4k or so, don't be shocked to see it fall back a couple of lbs as you cross beyond 5k or so.
The bolt diameters are roughly 6mm as I remember.
Old 09-19-2007, 01:37 PM   #3 (permalink)
tell you the truth i rarely go above 5K..RARELY..usually i shift at between 4K and 4.5K..i dont expect it to hold 10 pounds.. next week ima try to upgrade the exhaust....ill add 4 and do what ya said and see where i am. but thanks for the help
Old 09-20-2007, 02:42 AM   #4 (permalink)
well i did it...i shimed it.i put 3 1.4mm washers on each screw..yes i know i was gonna or supposed to use 2mm washers but the only thing i could get for free was 1.4 cause i had no money..since i put about 4.2mm of stuff i should have gained about 1.5 to 2 pounds of boost which is about what i got. so turned out pretty good.. gonna TRY to derestrict the exhaust nexy week so should be all good..lol.. thought id share my experience.
Old 10-08-2007, 02:13 PM   #5 (permalink)
Matt88's Avatar
View Matt88's Photo Gallery
where do you add these washers to the wastegate. sort of confused.
Matt88 is offline   Reply With Quote
Old 10-08-2007, 07:03 PM   #6 (permalink)
bgrieger's Avatar
It's held by 2 bolts. Put them between the wastegate and the turbo to pull it away...pretensioning the spring
Old 10-09-2007, 12:03 AM   #7 (permalink)
Matt88's Avatar
styll confused???
Old 10-09-2007, 02:33 AM   #8 (permalink)
take off your intake if you have a MKIII..your entire intake and you will see a golden colored thing..kinda like the bottom of a soda can and its held on by 2 12mm bolts.. take em out and put washers between the turbo and the gold bracket..theres a pic floating around somewhere
Old 10-09-2007, 10:07 PM   #9 (permalink)
Matt88's Avatar
the bracket holding the wastegate to the turbo
Old 10-10-2007, 12:54 AM   #10 (permalink)
yes
Wastegate or VSV problem? Mike@Fidanza MR2 Forum 2 05-09-2006 06:57 PM
How to make a 4-5 psi wastegate actuator! 97camryman Camry & Solara Lounge 8 04-17-2006 06:22 AM
wastegate type?? danboy MR2 Forum 10 08-08-2005 03:07 AM
? about ct26 wastegate 2drcam General Discussion 2 10-26-2003 07:36 AM
