old gas - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-06-2007, 08:39 PM   #1 (permalink)
View suprabran's Photo Gallery
old gas
the gas question is the car I bought a while back is getting ready for a new engine but the gas in it is at least 7 years old the inspection sticker says last inspected was 2000 so probably the gas is that old too. what should I do with the gas I was thinking just syhering it out and put new gas in or is there a way to make gas new like octane booster or any thing.
suprabran is offline   Reply With Quote
Old 10-06-2007, 08:54 PM   #2 (permalink)
CRE
View CRE's Photo Gallery
Octane booster would probably only make matters worse after that amount of time. Remove the old gas and try using it in your lawnmower.
CRE is offline   Reply With Quote
Old 10-08-2007, 07:01 PM   #3 (permalink)
one turbo is one too few
bgrieger's Avatar
Gameroom cash: $309050
View bgrieger's Photo Gallery
Trust me, even the lawnmower will not start well on it...have starting fluid (ether) or mix with waste oil on each oil change and send to the disposal per local regulations.
Old 10-11-2007, 06:35 PM   #4 (permalink)
thanks guys I was not going to use it unless there was a way to get it new like again I just pulled the drain plug and dumped it in a un useable gas can and put new fuel in it now I just need to get the newer motor dropped in and it will be ready.
Old 11-09-2007, 09:58 PM   #5 (permalink)
I wanted to write and tell every one you where right. I put the old gas in a lawn mower a week ago and it did not want to start and when it did start it finally died so I had to syhpone the gas out and put new in, and it worked fine. To every one good call I would have used it in my brother Blazer and probably got a black eye. so thank every one.
US gas vs. Canadian gas BenG General Discussion 13 05-23-2006 08:00 PM
Theory.. Exhaust gas accelerator fan Punisher Archived Corolla threads 16 04-25-2006 08:33 PM
Siphoning gas from 1996 Camry John5788 3rd & 4th Generation (1992–1996 & 1997–2001) 30 12-29-2005 07:12 AM
buying cheaper gas - Is it harmful? SolaraTRD General Discussion 19 03-27-2005 11:52 PM
gas related email i got spydrvnm General Discussion 3 02-29-2004 08:11 PM
