I'm not a fan of adding additives to oils unless I know precisely what other additives are in the oil already. The last thing you want is to mix two additives which either become caustic or emulsify when mixed and heated. Sometimes they just seperate and foam starving parts for oil... Leave the Lucas on the shelf.
You could use 80W-90, but I wouldn't. If you decide to use it in both, make sure it doesn't have any slip/friction modifiers already mixed in it. If you have a LSD add the slip/friction modifier as needed once the oil is in.
