Do I need to reinstall EGR? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-15-2007, 04:53 PM   #1 (permalink)
View grouseu's Photo Gallery
Hi everyone
I just bought a 1987 NA Supra with a thrown rod and I also purchased a JDM engine to install. I have swapped everything over necessary for me to install in the Supra (sensors, injectors, wiring harness, etc) but I am not sure whether it is necessary to reinstall the EGR system. The JDM block came with a block off plate on the rear of the engine.
This is not a California car so it has no EGR temperature sensor. Also, I do not have to pass any emissions testing where I live, so that will not be an issue. I have been told that deleting the EGR will cause the AF ratio to go rich, causing an oxygen sensor code to be thrown. I have also read that nothing at all will happen. The only connection this system has to the ECU is the VSV on the left rear of the engine, from which I read, turns the valve off and on according to manifold pressure. What, if anything, will happen if I neglect to reinstall the EGR system?
Last edited by grouseu; 10-15-2007 at 04:57 PM. Reason: hit enter key by accident oops
grouseu is offline   Reply With Quote
OBDII codes Phi Hardcore Tech and Competition 12 12-24-2011 09:38 AM
2000 Solara check engine light mytoyota02 Solara 25 10-16-2011 12:06 PM
P0401 EGR woes......... knkreb 3rd & 4th Generation (1992–1996 & 1997–2001) 31 11-12-2008 09:06 AM
Do-It-Yourself : Check Engine Light - Diagnosis bonnie* Archived Corolla threads 5 01-01-2007 02:12 AM
Egr system, What a pain in the rear! commutercar Archived Corolla threads 6 08-14-2005 02:46 AM
