MKIII short shifter question? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-16-2007, 02:24 PM   #1 (permalink)
UNATUL APIRTED's Avatar
View UNATUL APIRTED's Photo Gallery
i recently purchased a short throw shifter for my 87 toyota supra 7mgte. i just tryed installing it and realized its well lets just say not very fun. wondering if anyone has any info or a guide for installing this. i got down to the 4 bolts that you have to remove that in on top of the tailshaft but i couldn't get the two towards the rear of the car off. if anyone has any input that would be great. thanks
boost on!!
UNATUL APIRTED is offline   Reply With Quote
Old 10-16-2007, 06:13 PM   #2 (permalink)
Got Hardass?
Jeeves's Avatar
View Jeeves's Photo Gallery
The shifter should be real easy to install.
- Unscrew shift knob
- remove screws from dash piece (2x - in the ash tray bezel (remove the tray and you'll see 'em), 1 in the side near the ebrake, 1 (or two) on the left edge near the steering wheel.)
- Pull trim up (should pop out), then back, unplugging the random wires that are connected to the upper switches.
- Put stick into Neutral position
- look at shifter, move the rubber cover out of the way and you'll expose 4 - 10mm bolts. I think they are a phillips head, but use a driver and avoid stripping issues. Back them out.
- Pull up. Should come right out.
I don't think I've forgotten anything. Where are you getting hung up?
Old 10-17-2007, 01:30 AM   #3 (permalink)
alright well for one i cant get the damn shift knob that the previous owner put on...so i gotta work with that at the moment. but i got past the body panel if you will with the 4 10mm bolts. i got down to where the knob mounts to the plate which is bolted on the tailshaft. i got the front two 12mm bolts out but cant make room with anything to get the rear two bolts out. that is where i am stuck. any suggestions?
Old 10-17-2007, 03:18 PM   #4 (permalink)
Got Hardass?
Jeeves's Avatar
You aren't unbolting the plate (really called the tranny hat) from the tailshaft right? The shifter bolts in by itself.
Old 10-21-2007, 11:09 AM   #5 (permalink)
oh so the part that is actually has the 4 bolts on the "tranny hat" on the tailshaft itself i do not unbolt. how do i get the shifter out then after i have the upper plate part off that is connected to the shift boot and what not?
Old 10-24-2007, 11:02 AM   #6 (permalink)
Got Hardass?
Jeeves's Avatar
[img]http://xd.**********s.com/uploads/8d38fb5ee3.jpg[/img]
Hope that makes more sense.
Old 10-28-2007, 11:30 PM   #7 (permalink)
View Supra469's Photo Gallery
Cool. What type of short shifter did you buy?
Wanted: Toyota Back-up camera - Video Rearview Mirror - Air Bag for MR-S or Celica GT-S Steering Wheel
Supra469 is offline   Reply With Quote
Old 11-04-2007, 02:36 PM   #8 (permalink)
I Bleed TRD
willtotheumm's Avatar
View willtotheumm's Photo Gallery
let us know how you like the shifter. what brand is it?
1988 Supra Turbo- Stock 7M-GTE, 5-speed manual, HKS Turbo timer, ARP headstuds, planning 2jz-gte swap
1988 MR2- Stock 4a-ge, 5-speed manual, planning 20v swap
My Cardomain / My Myspace
willtotheumm is offline   Reply With Quote
URD Short Shifter Question offpiste 2nd Generation (2005+) 6 11-27-2006 05:24 PM
2004 Corolla S (Quickshifter or Short Throw Shifter) dormondlin Archived Corolla threads 4 03-09-2006 03:48 AM
best short shifter RedMK MR2 Forum 7 10-12-2005 09:03 PM
corolla sedan short shifter! Dicipleofthelie General Discussion 2 08-26-2004 11:32 PM
Short Shifter Question boosted Supra Forum 3 03-11-2002 05:20 PM
