question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-17-2007, 03:07 PM   #1 (permalink)
View viequesboy1's Photo Gallery
question
whats stand alone meens?
viequesboy1 is offline   Reply With Quote
Old 10-17-2007, 03:32 PM   #2 (permalink)
Got Hardass?
Jeeves's Avatar
View Jeeves's Photo Gallery
A stand alone means replacing the factory entire computer with a specialized one used for tuning. They are (more often than not) expensive, require wiring everything yourself, difficult to tune, and so on.
Old 10-17-2007, 06:54 PM   #3 (permalink)
JEEVES, MY PLANS IS TO SWAP A 2JZ IN A COROLLA BUT BUDDIES TELL ME CANT BE DONE BECAUSE OF WIRING ISSUES, BUT SOMEBODY SAID ABOUT THE( STANDALONE) ?WHAT YOU THINK go FOR IT ?IS IT POSSIBLE? THANKS MAN
Old 10-17-2007, 09:11 PM   #4 (permalink)
Import Tuning
camry man68's Avatar
View camry man68's Photo Gallery
Its possible but you have to be competent at wiring and you have to know how to properly tune the unit. There's alot of bad things you can run into when doing that kind of project. I recommend it only for those who know exactly what they're doing and how to do it.
camry man68 is offline   Reply With Quote
Old 10-17-2007, 11:53 PM   #5 (permalink)
Got Hardass?
Jeeves's Avatar
If you have enough money to throw at any problem, you can put any engine and any tranny into any car.
However, with that said. You don't know anything about Stand Alone ECU's, their programming, or how to go about that. That can either be an expensive fix, or things can get damaged. In my experience, if you don't have the know how to box in that arena, you should stay out of it. Just a basic setup used to run near $2,000 for a good stand alone. Prices (I think) have come down, but as I don't do any stand alone stuff, I've never had to deal with the horrid setup costs.
As I said, it's possible to do anything. all depends on the money, and what you're throwing at it.
Old 10-18-2007, 08:47 AM   #6 (permalink)
Pacquiao for president
supra saiyan's Avatar
View supra saiyan's Photo Gallery
Can't you just get a 2JZ with a complete engine harness and use a 2JZ ecu? I think you would have more problems fitting the transmission and rear diff from a RWD car into a FWD car.
supra saiyan is offline   Reply With Quote
Old 10-18-2007, 10:55 AM   #7 (permalink)
its a 74 rear wheel drive corolla
Old 10-18-2007, 10:56 AM   #8 (permalink)
thanks jeeves for looking out
Old 10-19-2007, 11:22 AM   #9 (permalink)
last question concerning swap
if i buy the whole front clip ?would the swap be 100%
Old 10-20-2007, 11:15 AM   #10 (permalink)
one turbo is one too few
bgrieger's Avatar
Gameroom cash: $309050
View bgrieger's Photo Gallery
no, the wiring still has to be dealt with. You can use te facotry ECU, but you still need to power it. You may also need to extend or reduce some harnesses and custom fit sensors. That's the "custom" part of the job. If you're not comfy with wiring diagrams and wiring, you may want to consider something different, or know and be prepared to pay someone to handle that part of the job for you.
Old 10-20-2007, 04:28 PM   #11 (permalink)
You might need to make a custom driveshaft, and you would probably want to use a 2JZ rear differential too since I don't think the one in the Corolla can handle the power. Then you'll need to make custom mounts for the engine, transmission, differential. Then find axles that fit. It's a lot of fabricating.
Someone on Supraforums did a swap into a late 77 Celica. http://supraforums.com/forum/showthr...ht=engine+swap
Old 10-20-2007, 07:35 PM   #12 (permalink)
I Bleed TRD
willtotheumm's Avatar
View willtotheumm's Photo Gallery
at first I was thinking one of the newer Corollas hahah.
but since it's in one of the old school ones this might be fun to watch
like they said... it all depends on how deep your pockets are...
1988 Supra Turbo- Stock 7M-GTE, 5-speed manual, HKS Turbo timer, ARP headstuds, planning 2jz-gte swap
1988 MR2- Stock 4a-ge, 5-speed manual, planning 20v swap
My Cardomain / My Myspace
willtotheumm is offline   Reply With Quote
2007 Camry Sound System Question mw817 5th & 6th Generation (2002-2006 & 2007-2011) 36 12-27-2006 07:33 AM
Sub/Amp question Elizle Audio, Video, and Security - Tech 5 07-13-2006 10:42 AM
Hell Question MR2Jedi Off Topic 11 07-06-2006 10:20 PM
2007 Camry Question skippy126 5th & 6th Generation (2002-2006 & 2007-2011) 5 05-24-2006 07:47 PM
general transmission question, 2nd, 4th and reverse do not engage!! afyouthbrigade Camry & Solara Lounge 1 09-29-2005 06:58 PM
