Question about removing a starter - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-10-2003, 07:34 PM   #1 (permalink)
View snowman6971's Photo Gallery
I have an 87 supra 7M-GE none turbo and today I wanted to remove the starter the bolt on the under side was no problem the bolt on the top is a real pain in the a$$, is there a trick to getting at it? I have almost all tools known to man but was having one hell of a time, I am removing the engine and leaving the tranny in place, any help would be great. I can`t seem to reach the top bolt, maybe there is a trick that I dont know thanks Randy.......
It`s a toy thing you wouldn`t understand.
snowman6971 is offline   Reply With Quote
Old 09-11-2003, 07:56 PM   #2 (permalink)
got it out thanks for the help.
Old 10-02-2003, 03:05 AM   #3 (permalink)
View hypnotoad's Photo Gallery
have exactly the same problem - details, please!
89 Supra non-turbo, sport roof; 00 4Runner SR5
hypnotoad is offline   Reply With Quote
Old 10-11-2003, 09:20 PM   #4 (permalink)
View cdnsupra's Photo Gallery
the key is too have the right socket, the right extensions, and the flex joint in the right spot. then you have to know where the socket has to go, because you cannot see it. you have to feel the socket into place.
people who have done it can do it again easily. people who have not have lots of trouble becuase they don;t know where to look.
Ben
CdnSupra from Hamilton
91T, stage 3+[87T has been retired]
cdnsupra is offline   Reply With Quote
Old 10-12-2003, 03:52 AM   #5 (permalink)
is there anything that can be written down, like which socket and extensions?
Is this a bolt with a nut on it (that has to be held in place with another wrench) or do the threads go right into the starter housing?
Old 10-12-2003, 08:10 AM   #6 (permalink)
N/A bites
Tercel GTS's Avatar
maybe you can grab a digi-cam and take pics, since you know where to look
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
Old 10-19-2003, 01:58 PM   #7 (permalink)
how-to details
got it out, here's details for posterity
slipped a 14mm open end wrench over the nut, which is on the front (toward front of car) side - dunno whether this actually helped, but since it's a real nut (not welded to the housing) I felt it would help stabilize so it wouldn't turn with the bolt. could not get the box end around the nut - too many obstructions
14mm 3/8in socket over the bolt head, feeling for it only (cannot see from above or below); next is flex-extension, then my two longest extensions (about 8in each)
keep everything as straight as possible along side the tranny (has to be bent at the flex a little, but the more it's flexed the less torque goes to the socket - don't round it off!)
use 3/8 ratchet and pull smoothly but firmly; I even used the side of the tranny to stabilize the extensions; keep left hand on the socket to prevent it from popping off the bolt head
starter can be removed from underneath but tight squeeze around the brake lines, wires, stablizer bar
Old 04-30-2005, 05:40 PM   #8 (permalink)
View tommi3's Photo Gallery
http://users3.ev1.net/~hmillerjr/starter/trans/ little hard to understand but there's pictures :]
tommi3 is offline   Reply With Quote
Old 05-09-2005, 09:33 PM   #9 (permalink)
View yotasrcool's Photo Gallery
Dont know if I can help with my advice, but Ive had a supra for a while and have changed starters on several others. I have found the easiest way for me is to get a floor jack, a ratcheting wrench and about a 3-5" long 2X4. I put the jack under the rear of the tranny and jack it up some, not alot, just enough to get some space between the firewall and the cylinder head. Then you can get to the top bolt with the wrench from the top. I have done this several times and it works great. Just my 2 cents! Almost forgot to tell you about the board! Wedge the board between the firewall and the cylinder head incase the jack slips you will still have an arm.
yotasrcool is offline   Reply With Quote
Old 05-12-2005, 09:17 AM   #10 (permalink)
Toyota Daddy
chinesemechanic's Avatar
View chinesemechanic's Photo Gallery
Lightbulb
You have to put a wrench on the nut and then take a 2-foot extension, a swivel, and your socket and give her hail.
chinesemechanic is offline   Reply With Quote
Old 05-17-2005, 10:01 PM   #11 (permalink)
View bosco659's Photo Gallery
When attempting to get at the top starter bolt, did anyone unbolt the rear tranny mount to tilt the engine back to get more clearance for the extensions / sockets?
I will be removing the whole tranny for a clutch replacement - any other tips?
Thanks
2000 Supercharged 4Runner
'89 Supra Turbo with a "few" mods
bosco659 is offline   Reply With Quote
