leaking steering rack - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-16-2007, 01:04 AM   #1 (permalink)
View osama1234's Photo Gallery
Canada leaking steering rack
Hi
I bought a used 86.5 NA supra that has a leaking 'steering rack'. The leak is mostly from around the banjo bolt area where the steering pressure line connects to the steering rack. From between the pressure line's connector and the start of the steering rack.
The old owner replaced the high pressure lines, and yet it still leaks.
I've tried tugging the banjo bolt, but i can't get it any tighter. I find the leak isn't so bad if i leave it alone, but if happen to turn the steering wheel to the end of its rotation, the leaking gets worse. ( i dont know if this last piece of info is helpful).
a) do you think its the banjo bolt or steering rack?
b) where could i get a banjo bolt (and the gasket around it) aside from toyota (which i suppose will really rip me off).
Thanks
osama1234 is offline   Reply With Quote
Old 12-07-2007, 08:38 PM   #2 (permalink)
View Supra469's Photo Gallery
Do you know if the crush washers were replaced also? Those really need to be replaced when this is being done.
Wanted: Toyota Back-up camera - Video Rearview Mirror - Air Bag for MR-S or Celica GT-S Steering Wheel
Supra469 is offline   Reply With Quote
Old 12-07-2007, 09:28 PM   #3 (permalink)
Got Hardass?
Jeeves's Avatar
View Jeeves's Photo Gallery
+1
Old 12-09-2007, 07:09 PM   #4 (permalink)
i actually dont. I didn't realize a washer went in there. I guess i'll remove it and put a new crush washer and see if it helps the situation. I'll have to get one from the toyota dealership?
Old 12-10-2007, 07:06 PM   #5 (permalink)
one turbo is one too few
bgrieger's Avatar
Gameroom cash: $309050
View bgrieger's Photo Gallery
it's under $10. If it's the one I'm thinking of, it's a one piece copper washer with rings on both ends and a tab joining them. One ring seals the bolt, one seals the banjo to the rack.
Old 12-10-2007, 07:19 PM   #6 (permalink)
Got Hardass?
Jeeves's Avatar
That's the right one. As far as I can remember, it's the only crush washer that's actually got them attached to each other. Wish they would have done that more.
Power steering rack rebuilt? Ilovemymr2 MR2 Forum 3 10-14-2006 03:17 PM
Power steering rack help! fincoon 3rd & 4th Generation (1992–1996 & 1997–2001) 7 07-31-2006 09:28 PM
Leaking Steering Gear? - Pics RedPhoenix Camry & Solara Lounge 11 12-14-2005 04:49 AM
How-To: 89+ Non-Airbag Steering Wheel into Pre-89 (MKIII) Jeff Lange Supra Forum 1 10-13-2005 01:17 AM
my power steering fluid is leaking mkII Camry & Solara Lounge 1 01-09-2003 08:23 PM
