New Problem: Read Post # 7
alright.. HG changed about 3 thousand miles ago. stock gasket torqued to 75 ft/lb..
never had a problem till about a week ago when i was driving around. the temp gauge didnt peg itself but it went close to the red. then settled back down. it does this occasionally. usually caused by air in the cooling system. well occasionally i get no heat at all.. i mean no heat. blows freezing cold. even if the engine is heated up.. on the way home from walmart tonight it was not blowing heat. i got to the top of the hill and the temp gauge wasnt pegged but it was close..NOT IN THE RED. it settled back down and i had heat..
HERES THE KICKER. i parked the car shut it off and opened the hood. the damn radiator is effin warm..not hot like it normally was but its warm and the engine was fully heated up...
WTF IS WRONG.. could it be the T-Stat is effin up? or whats your opinions
