Originally Posted by Jeeves
I believe the body harnesses were different too.
Have you tried the other door? If the alarm key sensor fell off the back of the lock, it won't detect it. However, if the car cranks, it's not the TD system. If it kicks in, you'll turn the key and nothing will happen.
the body is diff. but wires (color and sizes) are the same so its easy to de-pin and change the connector over about 10 mins of work.
Just rechecked wiring diagram and found out that you are right about the starter. The relay is grounded through the TD system.
Now the fun begins electrial problems are so much fun.
Will recheck all fuses, and grounds first. Then I will start ringing out all the wiring. Will let you know what I find, This might take a few weeks for me to get done.
Thanks for your help and time Jeeves
