Fuel issues! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-31-2007, 01:20 PM   #1 (permalink)
View teedoff00's Photo Gallery
Fuel issues!
So my car died the other day, and wont start, my aeromotive afpr gauge reads 0 psi for fuel. So I replaced the fuel pump and still no luck, the car cranks and cranks but no fuel is registrared in the fuel rail. I tried connecting the Fp to the B+ in the diagnostic box and nothing happened, when I connected the Fp to the battery the fuel pump relay resistor just buzzed. So I have no idea what to do next, I checked all the obvious fuses, the ign and egn in the kick panel, the ign and efi in the engine bay. None are blown. Any ideas please help!!
Thanks,
teedoff00
teedoff00 is offline   Reply With Quote
Old 12-31-2007, 01:45 PM   #2 (permalink)
Got Hardass?
Jeeves's Avatar
View Jeeves's Photo Gallery
Sounds like you might want to start taking power straight to the fuel pump (make sure you unplug the pump wires first. If that works, trace back wires.
Well, I've got a couple thoughts:
1 - FP Relay and Resistor pack on the passenger side strut tower.
2 - Wires to the fuel pump
3 - two bad fuel pumps
I'd try swapping the relay and resistor pack, if that doesn't work. Unplug the fuel pump wires and just try jumping it (backfeeding power to the components is baddd) from the battery. If that works I'd start looking at wiring. If that doesn't work I'd look at a dead fuel pump, or a clogged line.
Old 12-31-2007, 01:55 PM   #3 (permalink)
7MGTE/22RE
shaeff's Avatar
View shaeff's Photo Gallery
if all else fails, and you're planning to modify the car anyhow, a good thing to do would be the 12v fuel mod, as i outlined here: http://www.supramania.com/forums/sho...p+rewire+relay
or, you could temporarily bypass the resister/relay setup to rule those out in your quest for discovering the problem.
My heater core replacement writeup with pics: http://www.toyotanation.com/forum/t209136.html
1994 Toyota 4x4, 31x10.50, 22re. <- to undergo high compression 7MGTE swap whenever i finish building it.
1986.5 Toyota Supra- 300+rwhp. (capable of over 400, but i haven't tuned it yet)
shaeff is offline   Reply With Quote
OBDII codes Phi Hardcore Tech and Competition 12 12-24-2011 09:38 AM
URD CAI, MAF, Y-pipe, Magnaflow (Now w/ Video) Pb 2nd Generation (2005+) 361 09-09-2007 10:10 PM
On hybrids and fuel economy Bakemono General Discussion 5 08-09-2007 07:36 PM
GM to launch world's largest fuel cell fleet in '07 dsmnick General Discussion 1 09-17-2006 02:54 PM
help newbie save '85 with fuel system problem leiniesred MR2 Forum 0 02-28-2005 09:49 PM
