Neutral Safety Switch problem 1987 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-07-2008, 01:59 PM   #1 (permalink)
View wschmidt's Photo Gallery
USA Neutral Safety Switch problem 1987
The switch that prevents starting in any position other than PARK is becoming intermittent on my '87 Supra. It sometimes requires a forward push on the shift lever to engage the starter. I assume that the problem could either be a malfunctioning switch, or looseness in the linkage between the shifter and the switch. (The shift selector does seem to have a little more play than it used to have). Does anyone have any experience with this problem?
wschmidt is offline   Reply With Quote
Old 01-07-2008, 04:26 PM   #2 (permalink)
View toyomoho's Photo Gallery
Look at the location where the shift cable attaches to the lever on the trans. Determine if anything is loose such as an end fitting, lever, etc. The switch is normally mounted on the trans behind the lever.
where is the neutral safety switch located in a 1999 Camry? sswadi 3rd & 4th Generation (1992–1996 & 1997–2001) 4 03-18-2009 10:54 AM
Radio Error Message 06 Sport Taco 2nd Generation (2005+) 9 09-10-2007 08:45 PM
Neutral Switch ieatrice Archived Corolla threads 1 12-28-2006 03:01 PM
Neutral Safety Switch michoujordan76 1st & 2nd Generation (1983–1986 & 1987-1991) 11 08-19-2006 08:05 PM
ac switch problem homeguard Archived Corolla threads 0 03-19-2004 08:00 AM
