wiring diagram for power antenna 85 Supra - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-05-2008, 11:49 AM   #1 (permalink)
mk2-1jz's Avatar
View mk2-1jz's Photo Gallery
2nd Generation wiring diagram for power antenna 85 Supra
does anyone have a wiring diagram preferably color coded for the power antenna for an 85 supra. My antenna is missing and the harness is cut (no suprise) I have a power antenna from a 91 camry and am trying to splice them together. Hek if anyone has the diagram for a camry too that would be good, I need to know what the leads are so I can hook it up to my aftermarket radio, using the stock wiring, thanks
Build Thread: http://forums.celicasupra.com/showthread.php?t=53215
~ Jamie - 1985 Supra - 1988 Camry
~ Supra, Its a Religion
mk2-1jz is offline   Reply With Quote
Old 02-05-2008, 12:12 PM   #2 (permalink)
Got Hardass?
Jeeves's Avatar
View Jeeves's Photo Gallery
Should only be three wires (guessing, and maybe).
1 - +12V
2 - Ground (might just use a chassis ground)
3 - +12V Signal wire from Stereo (<1 Amp)
Old 02-05-2008, 12:31 PM   #3 (permalink)
mk2-1jz's Avatar
2nd Generation
ok so I just take any 2 wires that I can find that runs from the front to the back and tie them into power, then attach a ground from the antenna? then figure out what the wiring is on the antenna and connect them together?
Old 02-05-2008, 12:54 PM   #4 (permalink)
Got Hardass?
Jeeves's Avatar
You didn't say WHERE the antenna harness had been cut. I figured it was right there. Any random wires would be a baddd idea.
Old 02-05-2008, 09:24 PM   #5 (permalink)
mk2-1jz's Avatar
the harness is cut at the radio, I have all stock plugs in the back. The problem is I have no idea what wires comming from the radio were originally intended to hook up the antenna. Bascailly I have to harnsess that dont plug together. The hook up from the radio in the trunk and the plug on the antenna
Old 02-06-2008, 12:58 PM   #6 (permalink)
Got Hardass?
Jeeves's Avatar
Try this:
http://www.installdr.com/Harnesses/Toyota-Wiring.pdf
[img]http://www.**********s.com/supra/stereodiagram.gif[/img]
also:
http://www.installdr.com/InstallDocs...PDF/869033.pdf
