Help, headlights not working - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-21-2008, 01:22 PM   #1 (permalink)
View stuntdriver087's Photo Gallery
I was removing to clean under the carpet of my 96 Supra. I saw the integration relay hanging loosely so i disconnected it to find out where it belongs and put it back. The door light, low beam headlights, turn signals dont work only my high beams. I connected the integration relay and still none of those things work. Is my integration relay bad? Thanks
stuntdriver087 is offline   Reply With Quote
Old 03-27-2008, 04:25 AM   #2 (permalink)
View drifter28's Photo Gallery
Check the fuse for that light, or the bulb is damaged. Also, check the wire from the socket. I also have a 98 Toyota Supra and sometimes my headlight suddenly turn off. But like i said check to see if there is voltage getting to it before you rule out the bulb, I hope this helps
drifter28 is offline   Reply With Quote
