undercarrage - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-01-2008, 07:22 AM   #1 (permalink)
View suprabran's Photo Gallery
undercarrage
The plastic/rubber part under the engine is in really bad shape it basically fell off. Is this a vital part or not? If its not on the car will rust start to build up or even what is it used for?
suprabran is offline   Reply With Quote
Old 04-01-2008, 07:46 AM   #2 (permalink)
one turbo is one too few
bgrieger's Avatar
Gameroom cash: $309050
View bgrieger's Photo Gallery
The engine undercover. Many run without it, but it's purpose is to push air through the engine bay and it is an integral part of the cooling system. Some with marginal cooling systems find they immediately start overheating without it. Others run for years without it, presumably because they live in cooler climates or the system works well enough that the added benefit isn't needed for them...yet
Old 04-01-2008, 08:58 AM   #3 (permalink)
Got Hardass?
Jeeves's Avatar
View Jeeves's Photo Gallery
I honestly haven't run one for about 4 years. I know I should... I just haven't.
Old 04-01-2008, 09:19 AM   #4 (permalink)
bgrieger's Avatar
I ran for 5 without it and seemed to have no problems either, but it is something I have planned to get at some point again...it just keeps getting back burnered!
Old 04-01-2008, 10:56 AM   #5 (permalink)
Got Hardass?
Jeeves's Avatar
Yeah. Fuel System > Undercarriage cover :-D
Old 04-01-2008, 01:29 PM   #6 (permalink)
bgrieger's Avatar
fuel=engine=turbos=exhaust=pinetree air freshener=oilchange in the neon > undercarriage cover
Old 04-10-2008, 06:35 PM   #7 (permalink)
View cwtt's Photo Gallery
This is correct. I know for a fact on the MKIV Supra, the underpannel diffuser is a functional aerodynamic piece. It helps create a low pressure zone in the engine bay which forces air through the radiator instead of around it. Which in turn helps cool the car. Ask any road racer and they will tell you that you need to have it on. I have mine on because I see no reason to take it off. But you could probably get away with leaving it off on a street car if you wanted to.
cwtt is offline   Reply With Quote
Old 04-10-2008, 08:17 PM   #8 (permalink)
Thanks guys I will get one eventually, but nothing will rust will without it or will rust start forming?
Old 04-10-2008, 08:44 PM   #9 (permalink)
bgrieger's Avatar
one little piece of plastic ain't going to protect anything...if it was going to rust, it would with or without it.
Old 04-22-2008, 08:28 PM   #10 (permalink)
I Bleed TRD
willtotheumm's Avatar
View willtotheumm's Photo Gallery
a lil old thread (well, 12 days or so haha), but I had half of one of those on my Tercel (the other half flew off on the freeway haha) so I pulled the remaining part off. I never once had an overheating problem or anything due to it.
Now my Supra... it doesnt even have one. I'll probably try to find one thats in good shape to replace it with just because. I'm like Jeeves and bgrieger though, there are more important parts to worry about first.
1988 Supra Turbo- Stock 7M-GTE, 5-speed manual, HKS Turbo timer, ARP headstuds, planning 2jz-gte swap
1988 MR2- Stock 4a-ge, 5-speed manual, planning 20v swap
My Cardomain / My Myspace
willtotheumm is offline   Reply With Quote
Old 04-23-2008, 07:22 PM   #11 (permalink)
CRE
View CRE's Photo Gallery
I've noticed that when driving at *slightly* higher (not quite legal) speeds the suspension can start to feel a bit sloppy. When the undercover was replaced on two of the cars I've driven that effect was pretty much eliminated.
I haven't noticed a difference in temps in my own experience, but I don't doubt the validity of that either.
CRE is offline   Reply With Quote
