replacing fuel filter - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-19-2008, 08:24 PM   #1 (permalink)
View 3.0trd's Photo Gallery
Ok, this may seem stupid to some of you, but I'm having a hell of a time replacing my fuel filter on my 89 supra 5 speed. it sits on top of the differential and I can't figure out how they expect you to get to the damn thing! please help
3.0trd is offline   Reply With Quote
Old 04-19-2008, 11:02 PM   #2 (permalink)
one turbo is one too few
bgrieger's Avatar
Gameroom cash: $309050
View bgrieger's Photo Gallery
They didn't. There is no service interval. I don't believe a filter is "lifetime", but they do. You can continue to fight it blind, or remove the diff. I'm to a point I've taken the diff out so many times I would just drop it instead.
Old 04-20-2008, 01:10 PM   #3 (permalink)
I was hoping I wouldn't have to do it, but I think thats my only option. is there anything I need to know about removing it? can I drop it with the half shafts still attached?
Old 04-20-2008, 04:55 PM   #4 (permalink)
bgrieger's Avatar
unbolt the axles, the drive shaft and drop away. Shafts must all be removed.
Old 04-20-2008, 06:58 PM   #5 (permalink)
oh well, no big deal, was just hoping to avoid the disassembly for a stinking fuel filter, thanks a lot for the info!
Old 04-21-2008, 01:37 AM   #6 (permalink)
UNATUL APIRTED's Avatar
View UNATUL APIRTED's Photo Gallery
well idk about you but i would rather drop my tank than drop the diff. when i replaced mine i did a pump and filter. droppin the tank is only maybe 4-6 bolts. With the tank dropped its the easiest filter ever....granted once the tank is off.
UNATUL APIRTED is offline   Reply With Quote
Old 04-21-2008, 03:55 PM   #7 (permalink)
Got Hardass?
Jeeves's Avatar
View Jeeves's Photo Gallery
I did it with it all on the vehicle. It sucked but my tank was far harder to pull.
So, moral of the story? YMMV.
Old 04-21-2008, 04:48 PM   #8 (permalink)
I Bleed TRD
willtotheumm's Avatar
View willtotheumm's Photo Gallery
Get in good with people at an oil change place and use their pit. When my friend needed to replace a front axle, we used our work for it. When my general manager needed to replace an oil pan gasket on his 240sx, we used the pit, when I go to hang the HKS exhaust I want for my Supra, i'm gonna use Jiffy Lube's pit haha.
1988 Supra Turbo- Stock 7M-GTE, 5-speed manual, HKS Turbo timer, ARP headstuds, planning 2jz-gte swap
1988 MR2- Stock 4a-ge, 5-speed manual, planning 20v swap
My Cardomain / My Myspace
willtotheumm is offline   Reply With Quote
Old 04-21-2008, 05:28 PM   #9 (permalink)
7MGTE/22RE
shaeff's Avatar
View shaeff's Photo Gallery
I dropped my tank, alone, with about 5-7 gallons of fuel left in it. Fun? No. Easier than reaching all over the place, YOU BET!
Spray all the fittings down with PB blast for a few days, and make sure to use FLARE wrenches! It will make the job MUCH easier!
My heater core replacement writeup with pics: http://www.toyotanation.com/forum/t209136.html
1994 Toyota 4x4, 31x10.50, 22re. <- to undergo high compression 7MGTE swap whenever i finish building it.
1986.5 Toyota Supra- 300+rwhp. (capable of over 400, but i haven't tuned it yet)
shaeff is offline   Reply With Quote
Old 04-22-2008, 05:41 PM   #10 (permalink)
View suprabran's Photo Gallery
Is it this hard to replace the fuel filter on a non turbo, or is yours a non turbo also?
suprabran is offline   Reply With Quote
Old 04-22-2008, 06:44 PM   #11 (permalink)
I Bleed TRD
it's sure its the same for both.
Old 04-22-2008, 07:30 PM   #12 (permalink)
7MGTE/22RE
shaeff's Avatar
Definitely the same for both. There are very few differences between Turbo and N/A Supras. The chassis are the same.
