Problem with supra - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-22-2008, 05:45 PM   #1 (permalink)
View suprabran's Photo Gallery
Problem with supra
I don't know to call it a hesitate or stall. I will just explain what is going on. When I push the gas it takes a second to raise the RPMs. Like a jump. Once you push the gas pedal a second later it jumps it is like a skip or something. What could be wrong? I don't know really what to call it, between the three skip, stall or hesitate.
suprabran is offline   Reply With Quote
Old 04-22-2008, 07:03 PM   #2 (permalink)
I Bleed TRD
willtotheumm's Avatar
View willtotheumm's Photo Gallery
like its lagging on the throttle response?
1988 Supra Turbo- Stock 7M-GTE, 5-speed manual, HKS Turbo timer, ARP headstuds, planning 2jz-gte swap
1988 MR2- Stock 4a-ge, 5-speed manual, planning 20v swap
My Cardomain / My Myspace
willtotheumm is offline   Reply With Quote
Old 04-23-2008, 03:06 PM   #3 (permalink)
Got Hardass?
Jeeves's Avatar
View Jeeves's Photo Gallery
I had a problem like this, it was a broken spark plug wire and it only showed it's head under certain circumstances. However. at idle this may just be normal behavior. Under load it should do this same thing. If it does, I'd suggest you pull codes as my guess is that it's in a limp home mode of some sort.
Old 04-23-2008, 06:28 PM   #4 (permalink)
I Bleed TRD
yeah when my friend owned my Supra it was in a mode like that. That was on the old, rod-knocky engine though.
