battery problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-06-2008, 10:20 PM   #1 (permalink)
wambus
wambus's Avatar
View wambus's Photo Gallery
battery problem
New problem with my ride. I installed a used battery that had a full charge. It has been working fine for over a month. Now, suddenly, the battery does not have enough charge to turn over the motor - all other stuff works. When driving, the guage indicates about 14v being put out by the alternator. I am forced to pull off the negative terminal each time I stop in order to start up again. I had to replace the last battery because the brake light switch failed; the car was not being driven so this was not noticed until the old battery was stone cold dead. Any common problems to look for in this regard?
wambus is offline   Reply With Quote
Old 05-07-2008, 12:29 AM   #2 (permalink)
Got Hardass?
Jeeves's Avatar
View Jeeves's Photo Gallery
I've never had this problem, but I believe the alternator has a diode or a diode pack that can fail. This will cause the battery to unload back into the alternator when the car is off, thus killing the battery. A warm alternator hours after the car is off is a good indicator of this (as it should generate a decent amount of heat)
Old 05-07-2008, 12:40 PM   #3 (permalink)
wambus
wambus's Avatar
If I have the battery on a charger and also still connected up to the cars's cables, will that current flow back to the alternator and warm it up? Other than that test, how can I tell if this is the problem?
Old 05-07-2008, 10:30 PM   #4 (permalink)
Got Hardass?
Jeeves's Avatar
Take it (or the car) to an autozone, or a checker or something of the sort. Most of those places can test alternators.
