Weird intercooler piping - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-08-2008, 03:37 PM   #1 (permalink)
I Bleed TRD
willtotheumm's Avatar
View willtotheumm's Photo Gallery
3rd Generation Weird intercooler piping
is it me or is this just a weird way to intercooler piping?
http://cgi.ebay.com/ebaymotors/86-92...spagenameZWDVW
I was browsing the pics and then said WTH to it going up to the firewall and then over to the intake. Maybe its just me.
Either way... i'm not gonna buy it.
So... happy bidding! LOL
1988 Supra Turbo- Stock 7M-GTE, 5-speed manual, HKS Turbo timer, ARP headstuds, planning 2jz-gte swap
1988 MR2- Stock 4a-ge, 5-speed manual, planning 20v swap
My Cardomain / My Myspace
willtotheumm is offline   Reply With Quote
Old 05-08-2008, 10:25 PM   #2 (permalink)
View Fubar231's Photo Gallery
I actually like how that intercooler piping is routed, i would rather have mine down along the side and crossed over, i thought about making a custom pipe for that myself. I actually like this more because its down the side, its out of the way, and eaiser access to a turbo compared to removing the stock intercooler piping.
EDIT: It doesnt run up to the firewall, it runs parallel to the 3000 pipe then cuts over, just running up the side of the car then crossing over instead of in the way of everything.
Fubar231 is offline   Reply With Quote
Old 05-08-2008, 10:35 PM   #3 (permalink)
one turbo is one too few
bgrieger's Avatar
Gameroom cash: $309050
View bgrieger's Photo Gallery
...it hangs lower than the hold downs and engine cross member, so if you use an engine undercover, you have to dump it from the looks of it. The pipe is also the lowest point...hope the car isn't lowered or there are no speed bumps around.
Now as to the engine bay, it's a little longer route than stock, but definately a personal preference. I'm not big on the look, but I know many who do like that route as well, and have made it look good.
Old 05-08-2008, 10:44 PM   #4 (permalink)
Whoever made this is a retard because the piping is horrible yes, but i just like the general style / layout of the piping in the engine bay.
Old 05-09-2008, 01:12 AM   #5 (permalink)
Got Hardass?
Jeeves's Avatar
View Jeeves's Photo Gallery
They may have made it clean, but they also added like 12" of overall length.
Old 05-09-2008, 10:21 AM   #6 (permalink)
Yeah roflmao jeeves
Old 05-09-2008, 12:08 PM   #7 (permalink)
I Bleed TRD
what if you just eliminate the cross over pipe altogether with an intake manifold like this?
Old 05-09-2008, 12:41 PM   #8 (permalink)
bgrieger's Avatar
A front face manifold. They do shorten the path, but add a series of other concerns. Alternators usually need to be dropped down, or the AC has to come out to put the alternator there. Then there is the throttle cable and throttle body...none of it's rocket science, but it does add complexity and custom to the mix.
Old 05-09-2008, 12:48 PM   #9 (permalink)
I Bleed TRD
yeah I read the alt needs moved. Good thing I pulled my A/C!!! hah.
I didnt however, think about the cables like you said. Yup... i'd rather stick stock for now.
Old 05-10-2008, 03:37 AM   #10 (permalink)
Got Hardass?
Jeeves's Avatar
I full well plan on going FFIM. The over the engine crap is ridiculous. Stopped with manifold temps at 75ºF, started back up ten minutes later, manifold temps were 130ºF.
Ugh.
Old 05-10-2008, 09:17 AM   #11 (permalink)
bgrieger's Avatar
Ugh.
I'd like to eventually do it too, but that temp should drop quickly enough once you're under way again after a restart. Besides, while the hot side is a little warmer after stopping, the whole engine bay gets near that hot once the air flow stops, so you might only get it down to 115-120 instead of 130.
Old 05-10-2008, 07:51 PM   #12 (permalink)
Got Hardass?
Jeeves's Avatar
It does, a mile down the road I'm back to 80degF, just sucks something vicious.
I realize the whole bay will warm up, but I find it hard to believe that if I've got 12" of piping between my IC and my manifold that it'll heat up to too ungodly temps. I just find that any piping that goes over the engine will deal with temps that otherwise would be unnecessary.
