Valve Clearance Adjustments - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-15-2008, 01:26 AM   #1 (permalink)
UNATUL APIRTED's Avatar
View UNATUL APIRTED's Photo Gallery
So i finally got my head back and got its all torqued down. Went to check my valve clearances and pretty much all of them are to tight. I know you must shim them to get the correct clearance. just wondering if anyone knows where i might be able to find a shim kit? thanks
UNATUL APIRTED is offline   Reply With Quote
Old 05-15-2008, 09:37 AM   #2 (permalink)
one turbo is one too few
bgrieger's Avatar
Gameroom cash: $309050
View bgrieger's Photo Gallery
Toyota sells the shims Once you know the sizes you need to get back in spec (measure min and max for each valve), take that list to them and select from the list they have of available sizes. Time consuming, but I remember the shims to be reasonably priced when you need only some.
Old 05-15-2008, 12:34 PM   #3 (permalink)
yeah i have the list of clearances right now..i just have to take the old ones out and measure them. thanks for the help
Old 06-12-2009, 03:43 PM   #4 (permalink)
Racer0ne
View craig stone's Photo Gallery
You can also use shims for Yamaha motorcycles.I believe the same diameter as a FJ 1100/1200 and the Venture Engine.If you like I can find out.
Racer0ne
craig stone is offline   Reply With Quote
