Originally Posted by wambus
It just seems odd that it is just the passenger window - both switches. The driver window operates perfectly. For a while i could reach over and use the switch on the passenger door, but not now...
Any special tips on the switches, other than avoiding "SPROINGGGG"?
Those switches are nightmareish. They are the epitome of 80's design. Overly complex, 12039123 tiny pieces, and parts that fail often. I've actually got the plastic clip from a $1.29 mechanical pencil holding my passenger switch together.
When you get it open, be VERY careful to note where pieces come from. You've got copper rocker arms, small springs, plastic pieces, etc. Real quick here're my notes.
The pieces that often get corroded/fail to function are in the base contacts and the rocker arms.
[img]http://www.**********s.com/supra/windowswitch.png[/img]
I'm also not drawn some parts intentionally, as they'd get in the way. You'll have lots of little screws, a plastic cover or two, and the actual rocker switch will snap out too. etc.
Often the tips on that copper rocker arm get dirty or nasty from arc-ing. In mine, I took a dremel with a wire brush tip, and cleaned both bits till they shined something fierce. They've worked great (minus the window coming off the track) since. I also did the same things to the copper contact points on the bottom half of the switch. Applying a little lithium grease to the sliding white pressure point (which resides in the stem of the switch itself) will add a little life and make sure that it doesn't get stuck in its track.
Note: With the driver side controls unplugged, the passenger side won't function.
