Originally Posted by BLUEVTEC18
Hello everyone.
My father-in-law has an automatic '89 Supra Turbo that doesn't start/run. As I understand, everything else about the vehicle is road worthy. We figured out there is no spark but we don't know why. I was thinking it might be the ignitor which is located on the driver's side near the battery. We haven't found any broken wires, bad relays, or blown fuses. Is there some way to check if the ignitor is receiving power during cranking? Or am I off base here? What else could cause a "no-fire" situation in this vehicle?
Any help in guiding me with troubleshooting the "no-fire" is gladly welcomed.
Thanks in advance,
BLUEVTEC18
Easiest way to check for spark is to pull the #1 plug wire, plug a spark plug into it, ground it out against the chassis, and crank. If it starts sparking, you've got spark
More common on the turbo cars, the wires to the Cam Position Sensor get damaged. These will prevent the ECU from knowing what the timing is, without knowing the Timing, the car won't run. This is a sensor located on the passenger side of the engine, about as far forward on the head as it can be. It is behind the bracket that holds the power steering reservoir. I believe it has 4 wires.
Jiggle them, then try starting it again.
That's it, but on your engine, it'll have a black cover over it.
