Think my tubo is going bad help!!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-18-2008, 12:38 AM   #1 (permalink)
View Fubar231's Photo Gallery
4th Generation Think my tubo is going bad help!!!
So my car doesnt not overheat, but im pretty sure it is burning coolant and i think its a sign that the turbo is going to go? Ill put some coolant in, not much, and then a few days (2-4) later, the coolant light will start flashing when i turn and stuff, then another 2 days or so it will be on. Turbo going bad?
(Woops on the GEN4. 89 Turbo MA70. Stock Ct26)
Fubar231 is offline   Reply With Quote
Old 06-18-2008, 05:38 PM   #2 (permalink)
Got Hardass?
Jeeves's Avatar
View Jeeves's Photo Gallery
Nope, of all the things to consume coolant, the turbo is the last I'd assume.
BHG is far more likely.
Edit:
And the 89 Supra is a Mk3 (3rd Gen.) not a 4th.
Old 06-18-2008, 05:53 PM   #3 (permalink)
I doubt its a blown head gasket because my temp never goes above what it normally goes too. And you can smell like burning coolant it seems like or something.
I know that jeeves, thats why i put woops on the gen 4.
Old 06-19-2008, 12:15 PM   #4 (permalink)
Found the leak. Rotted radiator. Slowly draining out, how hard is it to replace the radiator on the 7m-gte? Ive done it on some 305's and 350 camaros and stuff but never a import.
Old 06-19-2008, 04:23 PM   #5 (permalink)
Got Hardass?
Jeeves's Avatar
Nope, pull the two upper brackets. Remove the smaller A/C Fan (3 bolts?). Remove the hoses (including the small overflow hose) and the fan shroud (has some bolts). Lift straight up. Can't say how the automatic is.
Old 06-19-2008, 05:20 PM   #6 (permalink)
Any radiators you recommend that arnt from toyota? Make a somewhat aftermarket aluminum one or something? What would you use.
Old 06-20-2008, 01:54 PM   #7 (permalink)
I Bleed TRD
willtotheumm's Avatar
View willtotheumm's Photo Gallery
i've heard Koyo radiators are good ones. koyorad.com
1988 Supra Turbo- Stock 7M-GTE, 5-speed manual, HKS Turbo timer, ARP headstuds, planning 2jz-gte swap
1988 MR2- Stock 4a-ge, 5-speed manual, planning 20v swap
My Cardomain / My Myspace
willtotheumm is offline   Reply With Quote
Old 06-20-2008, 02:01 PM   #8 (permalink)
Wow them are expensive, uh do you know any that have automatic transmission coolers built in? I kinda like the whole stock auto trans cooler, so if i cant find one with one built in i think i might look at getting one directly from toyota.
Old 06-20-2008, 09:25 PM   #9 (permalink)
one turbo is one too few
bgrieger's Avatar
Gameroom cash: $309050
View bgrieger's Photo Gallery
The koyo's are pricey...but they are pretty (and about double the thickness of the stocker). I'm not sure if PWR/fluidyne/haste/mishimoto have any with the auto tranny cooler built in but CSF has an all metal stock replacement that's popular that does have it. I'd not recore the stocker as the plastic end tanks eventually fail (split open, then you get coolant everywhere).
Old 06-20-2008, 10:37 PM   #10 (permalink)
Is this one of the radiators you are talking about? Wich one of the two would you recommend?
http://www.autopartswarehouse.com/se...Toyota%20Supra
I was thinking the one on the top for 179.
Old 06-21-2008, 07:17 AM   #11 (permalink)
bgrieger's Avatar
CSF lists it as their part # 2200...I can't tell the difference on the site you listed.
Old 06-21-2008, 11:49 AM   #12 (permalink)
I found the radiator i need. The #2200. But i cant seem to find the same radiator on any other website, and you cant order it directly from the csf radiator website so, what do you guys suggest?
Old 06-21-2008, 10:56 PM   #13 (permalink)
bgrieger's Avatar
ask the shop...if they can't tell you, try another one. There should be no shortage of places willing to give you what you need...
Old 06-24-2008, 12:29 AM   #14 (permalink)
Does the #2200 CSF Radiator have the automatic transmission cooler in it? I was told it didn't have it.
Old 06-24-2008, 08:19 AM   #15 (permalink)
bgrieger's Avatar
I picked the detail up from the CSF catalogue which included the drawing of the supra rad including the cooler. If I were you, I would head to CSF's website and ask them. Given they make it they should be able to give you an answer first time, rather than asking a whole whack of people their thoughts on what it has...
